Electric motor advice/sourcing help needed.
Looking for help finding an affordable variable speed motor for a test setup I'd like to build over the winter. I'm trying to do some horsepower (via wattage) measurements of differing engine mechanical fans. I've always distrusted the results I've seen in hot rodding type magazines, as the tests were always done on a static engine dyno (where the fan has to pump a lot of ambient air), whereas in the real world there is varying "wind" speeds entering and exiting the radiator due to the vehicle speed, and this varying wind exit speed should affect the instantaneous angle of attack (for lack of the correct phrase) that the fan blade sees in the moving air. I'd like to vary both the fan RPM (up to about 5000) and the (radiator exit) air speed hitting the fan blades, and measure the electric motor current (and then convert to horsepower) to see what the horsepower requirements are in a somewhat real environment. I don't know at this point what the motor horsepower requirements would need to be, so that's just one of the many unknowns. (I've got another aspect of mechanical fans I'd like to measure, but you'll think I'm crazy if I go into detail on that at the moment, so I'll leave that discussion for later.)
I'm not an electric motor expert, so any helpful suggestions of what might work, and where to get a motor (used and cheaper is preferred) to do this experiment is appreciated.
Thanks.
Find a cheap or free treadmill on Craigslist, the type that has a knob on the control panel attached to a potentiometer to vary speed.
Obviously, a DC motor would be the easiest way to do the conversion at varying speeds. Any idea of the peak HP required (in order to "size" the motor - X watts at 5000rpm)?
All I know is the Dual Spals I have are supposed to spike to near 40 amps on startup, running in direct parallel with each other, no single fan operating setup....and ~25 amps running......my FI computer will turn off the spals when reaching about 40 mph for a few seconds.....a/c running or not......
IMO, any fan at ~45 mph+ is just blocking airflow.....
I don't have a good idea of what the hp requirements are yet, and unfortunately I won't really know until after the test. I've heard some outrageous numbers from some people for the fan drain, but I don't buy it. At the moment I'm just shooting for the most motor I can find at a reasonable price.
I agree, but it just seems to me that a turning mechanical fan is going to block less air than a non-turning electric fan. (I can't easily prove it at the moment though.)
INteresting point, got NO clue, but I have to ASSume that the fans of any type are being forced to turn at ~45 mph no matter what type they are.....would be curious to know about the mechanical fans and what you are exploring, must be about your racing/class requirements......I"m just an old street racer.....:p:beer:
Gene said the fans are @ 25 amps running and I have heard that number before. That's 300 watts. 300 watts @ 5000rpm is a big motor.
Okay, this is where I'm a bit foggy. Three hundred watts is less than half a horsepower (.4 hp). I don't have a good feel for what RPM that electric fan is at when consuming that four tenths of a horsepower (and then trying to somehow extrapolate the power draw at 5000 RPM).
Meanwhile, I'm trying a simple experiment until I can get back to my favorite scrap yard where there's usually a treadmill or two thrown in the pile. Dug around in my dad's shop while recently visiting my mom. Found a one horse motor (3450 RPM) with a 5/8" shaft, the same size as the w/p shaft on the Corvette. I tried out a spare fan spacer I had, and it looks like I can bolt up my flex fan to this setup to do an initial test. Here's the motor and spacer:
The only question yet is transferring the torque and retaining the spacer on the shaft. The shaft has a keyway, while obviously the fan spacer doesn't. I was kicking around putting a couple set screws into the keyway unless there's better options available (and I'm all ears). Also, I've got a AC breakout cord to allow me to measure the motor current. I don't have a strobe tachometer, so I'm still trying to figure out how to measure the motor/fan speed.
I like that! Thanks.
No problem. It's a good way to upgrade band saws, drill presses, and other power tools to PWM-controlled DC power as well. Those things are rated to have humans running pushing against the bearings, they'll drill through things just fine. They usually have a speed controller board buried somewhere inside, usually near the motor. The units with push-button controls are harder to adapt, and there are a few old treadmills out there with AC motors and mechanical speed-change mechanisms.
All I should say is; "Golly, Mr Wizard!"
As I understand 12 fans - unless you lock it mechanically/electrically - it will free wheel (spin) without being "on". Minor - nearly immeasurable drag there I'd think.
Cheers - Jim (aka - Jimmy)
I hand spun one of my spare electric fans (for my street rod), and there's noticeable magnetic drag on it. I was somewhat curious if there was some way to get some "free" recharge energy out of it while cruising down the road, but between the magnetic drag and the inefficient pitch when used as a "turbine", instead of a prop, I'm not convinced that these things freewheel that well.
Pulled a motor out of a junked treadmill the other day. Two and a half horse DC motor. Hooked it up, and damn, the thing works.
I still need to figure out the belt drive setup yet. The treadmill had a flat multi-groove belt on it, while I'd like to just be able to use a Vee belt and some of the spare pulleys I have laying around to get the fan speed I want.
Looks like a threaded 7/16 shaft that the flywheel/pulley assembly is threaded onto. I'm trying to decide what's the easiest/cheapest way to put a regular vee pulley on it. I got a few ideas, but I just gotta take a closer look at some available pulleys to see what makes the most sense.
I've got the circuit board that controlled the motor speed (the control panel was digital, but I don't know yet if the signal to the motor board was analog or digital), and now I just gotta decide how much of it I want to use, and how much I want to bypass. I also need to decide the best/cheapest/decent-accuracy way to measure the fan RPM and the motor power consumption.
I'd just plug in the motor control board and find a place to mount the speed control pot. That way you have PWM-controlled motor capable of anything from 0 rpm to the maximum rated rpm.
