Go Back   VetteMOD.com > VetteMOD Technical Discussion > Engine
  #11
Old 09-28-2019, 03:30 AM
COLE SWEAT's Avatar
COLE SWEAT COLE SWEAT is offline
United States | Member
My Photos: (0)
So is it required?
  #12
Old 09-30-2019, 11:01 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (313)
The information I have found so far tells me that the bypass is required. Mostly from tech info about industrial centrifugal pump applications where the pump is "deadheaded" (like a car engine when the t-stat is closed). In a car, the bypass allows the coolant to temperature to "even out" though the engine because there is (bypass) re circulation when the t-stat is closed.
The bypass also allows the pump to provide minimum flow under deadheaded conditions which reduces cavitation and pump failure (pump is churning water without flow). This is from an industrial site:
In order to ensure adequate cooling and lubrication of the pump, there must be sufficient volume flow through the pump. Inadequate cooling and lubrication leads to overheating, bearing wear, friction between the sealing faces, leaks at the shaft seal, all of which will lead to pump malfunctions or failures. This is why a bypass line needs to be installed if there is a risk that the pump cannot be operated at the necessary minimum flow rate.
The bypass line is to be drawn from the pump's vent port or the discharge pipe's vent port, either back to the suction side (if possible) or into a tank, in order to ensure sufficient cooling by the pumped medium. On return, it must be possible for the pumped medium to cool down before it is fed back into the pump in order to avoid overheating the pump. For this reason, the bypass line must never be connected directly to the pump's suction port. The bypass line has been configured correctly if the minimum flow rate requirements for the respective pump as specified in the operating instructions have been fulfilled. At full load, the volume flowing through the system and the bypass may not exceed the maximum flow rate delivered by the pump.
  #13
Old 10-13-2019, 12:52 PM
BBShark's Avatar
My Photos: (313)
Follow up:
I ended up using a traditional by-pass hose. I considered machining the other port and talked to someone at Edelbrock. What I was told is that, since this is a reverse rotation pump, opening that port would probably not do anything. Depends on the impeller housing.
Now to find a 2" radiator hose coupling with a 5/8 T fitting for the heater hose return.
  #14
Old 12-24-2019, 11:13 AM
COLE SWEAT's Avatar
My Photos: (0)
On a sbc there is no bi pass hose, I don,t see the need.
On our boats we donít use it but we Donít have a radiator. Water pump work good without it.
  #15
Old 12-24-2019, 05:25 PM
BBShark's Avatar
My Photos: (313)
SB Chevy is bypassed internally. No hose.
  #16
Old 01-25-2020, 07:15 PM
Geoff Coenen Geoff Coenen is offline
My Photos: (0)
The 63-67 327 Corvette with HiPerformance has a bypass hose on the water pump right from the factory. But 327 is old school to new school LS...
63 340 & 360 HP
64 & 65 365 & 375 HP
65 ? 350 HP - CRS
66-67 350 HP
  #17
Old 02-02-2020, 11:14 AM
mdbelanger's Avatar
mdbelanger mdbelanger is offline
United States | Almost broke my 3rd.....member
My Photos: (2)
How about just taping the heater return line into the bottom radiator line.
IMPOTENCE:
Nature's way of saying, "No hard feelings".
  #18
Old 02-02-2020, 11:22 AM
BBShark's Avatar
My Photos: (313)
That’s what I’m going to do.finaly found a tee section for the lower hose
Hose Tee
By-pass hose
