After several track days with some reasonably soft tires (Hoosiers) I've noticed that I'm wearing the inside of the tread more than the outside. I have minimal static negative camber on the fronts so I'm thinking I have too much camber gain. Seems like a little less camber gain might be the answer, but it would also help keep the tires more vertical during hard braking (due to any nose dive issues), so that should be two improvements from one change. I'm thinking that raising the UCA inner pivots upward should help out. The ride height is currently a little higher than this old picture, but it does show some angle on the upper control arms.
The UCA mounts are removable/unboltable from the frame (in the event that I wanted to alter the front geometry), but in the mean time I was thinking about making some spacers to raise the mounts up a bit to see what height gets the geometry where I want it. I can then just weld up some new UCA mounts when time permits and swap them in.
I don't know how to "calculate" an ideal virtual swingarm length for the suspension, so it seems that some trial and error adjustment is necessary (correct me if I'm wrong) to get the camber gain correct. Make sense, or am I missing anything?
