jsssgrl1209
Banned
I am trying to find out what rear is in my 81 corvette. I know from the bolts it is a dana 44 but I am just trying to identify the year.
When I bought the car it had a 350, th400 trans and whatever rear is in it now.
When driving on the interstate the car would be doing 65mph at 3000-3200 rpm. This leads me to belive that the rear ratio is between
3.70 and 4.11. 81 corvettes only came through with 2 sets of gears from the factory. 2.83 and 2.87 or something close to that.
This means either someone swapped the entire differential or someone swapped the gears. I already know they swapped out the original transmission for the old th400.
Since owning it I have swapped in a big block 427 with 2 4 barrels, nitrous kit, 6 speed t56 transmission, side pipes, stinger hood and a lambo door kit.
Now I am looking to put a set of 4.56 in and want to make sure I am buying the right gears.
Any help would be appreciated! I was under the car today and couldnt find any numbers on the differentiol. But it would help if I knew where to look.
