69427
I've had a weeping brake line on the main junction block since I put new lines on the car. Of course, it has to be the bottom line that is difficult to see, and routes across the crossmember to the RF wheel. I put another short, plugged line on the junction block to see if perhaps the problem was my crossmember line, or the flare seat in the block. It's still leaking after applying pressure on the brake pedal, so I'm guessing the seat is scarred. I suppose I'm not surprised if there are some seat issues, given how stinking hard it was to remove the original lines so I could run the new custom lines. So, before I spend the money on a new junction block, is there a decent way to refurbish the internal seat on this block?
Thanks,
Mike
Thanks,
Mike
