  #511
Old 02-08-2019, 11:49 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (269)
A bare frame for a C3 is 285lbs.
  #512
Old 02-09-2019, 04:18 AM
SuperBuickGuy's Avatar
My Photos: (0)
Quote:
Originally Posted by phantomjock View Post
Any chance you can get a weight on the frame and the body separate? Just that they are apart now and would be useful. I'm going to post a "CG Guestimator" I put together in another thread.
I'm not sure a frame weight would be accurate because I've front and back halfed it.... I'll see about the body - though that said, the brake system, interior and about half the dash is in place and there's a huge hole where the back used to be.....
  #513
Old 02-09-2019, 12:03 PM
phantomjock's Avatar
My Photos: (699)
Any numbers as long as we know the limits are helpful. BBShark - thanks for the Frame weight. My "guesstimate" was about 85# light (using the Camaro numbers).
Rebuilder's Zen Saying:
  #514
Old 02-11-2019, 01:52 AM
My Photos: (0)
a bit further
and now flip the frame over
lots easier to weld this way
​​​​​​​as for weight, didn't get to the body, but the frame has to be 500# as pictured
  #515
Old 02-12-2019, 03:33 AM
My Photos: (0)
the snow is great, best of all, I get more time on thisedited
front end disassembled
mental note, that makes the rear heavier....edited
so let's disassemble it as well
I did get more welding in on the frame rails
what is that term - it's a 50/50 chance you did it wrong... wrong, I think it's more like 100%... in the case I have to cut the e-brake cable bracket to remove the rear assemblies
it's apart
and now, because of the snow, I'm wondering if I should just clean it well then paint it... I'll have to decide after tomorrow - there is a bunch more welding to do.... once that's done, it'll be time to get it clean so I can paint and start reassembly for real.... which is good, I'm running out of places to stash C3 parts.
  #516
Old 02-13-2019, 04:26 AM
My Photos: (0)
thread protectors
hey look, cheap disks explode - it's why I wear expensive, safety gear
welding up final holes
Tomorrow, grinding then hoping the snow goes away enough to take the frame to be blasted.... if not, I'm sure I'll think of something
  #517
Old 02-13-2019, 11:16 AM
My Photos: (699)
There was mention of the "kit" opportunity this build sort of indicates. Maybe a set of dimensioned drawings of each end, a bill of materials, and a tip-sheet would be useful. Maybe not everyone has the skills to do this job, but with the drawings they could hire someone who can.
Open Source? Sold as a plan set? There are several folks here on VM that could help with making a good set of drawings, Solidworks, Rhino, or even SketchUp that could be pdf'ed to a useful size.
Just early morning thoughts over coffee.
  #518
Old 02-13-2019, 06:30 PM
My Photos: (0)
most of it is already available with those C5 plans I posted earlier. The last of it would be locating the pins from the datum line.... I'll measure it again, then all of it is available if someone wants to do the work.
  #519
Old 02-17-2019, 11:11 PM
My Photos: (0)
caution, there is some snark contained within this - it's not for this site, but for some reason (other forum) people think their opinion is quite something. My apologies, but you folks are great and it's not intended towards you
today started with deciding I'm not using this (still).... it's an aftermarket, bolt-in cross member but I think the stock, welded cross member is stronger
So I did what was naturally the next step, I cut out more of the frame (so the purists will cry, I guess)
just for the record, this isn't a discussion - this is what I'm doing, like it, hate it.... don't care.
as I cut it apart, nothing popped out of shape - which is good, considering how pretzelled this frame is
and just like that, 40# lighter
now to figure out how to put the upper shock mount back... no... how much floor I'm willing to cut out to put the shock in the right place
​​​​​​​isn't there anymore.
  #520
Old 02-17-2019, 11:41 PM
rtj's Avatar
rtj rtj is offline
My Photos: (65)
Thanks for the warning.
Personally, I always want to do as much as I can myself and learn. Some people can’t understand that concept.
Anyways, it looks like you are making progress and will be out driving the wheels off soon.
