  #391
Old 09-13-2018, 01:04 PM
rtj's Avatar
rtj rtj is online now
My Photos: (58)
Quote:
Originally Posted by SuperBuickGuy View Post
they're always my last option because it usually takes at least a week to get anything from them.... I think I have the right ones now, but I need to get a car off the lift to go back...
In other questions, are there aftermarket, manual racks for the c5/c6?
On the grand am power rack, I just crossed the hydralic lines and used it as manual. It may work on a c5.
Edit: quick search shows photo of c5 rack with a “jumper” hose on the pump connections.
  #392
Old 09-13-2018, 10:21 PM
SuperBuickGuy's Avatar
My Photos: (0)
Can you feel the valve in the rack when you're driving?
  #393
Old 09-13-2018, 11:25 PM
rtj's Avatar
My Photos: (58)
On the grand am rack, no issues. I crossed the lines, I’ll see if I can find an old photo.
The only thing I really should do is make new bump steer blocks that give me a tighter turning radius.
The guy that posted the c5 fix was over at CF.
  #394
Old 09-13-2018, 11:52 PM
rtj's Avatar
My Photos: (58)
Discussion here:
  #395
Old 09-14-2018, 11:28 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (264)
Looping the line (in-out) works.
  #396
Old 09-14-2018, 07:47 PM
My Photos: (0)
Quote:
Discussion here:
I read the discussion and it doesn't seem like anyone said "I tried it and it worked"
the thing I'm curious about. If you pull the power steering pump off a C3, the valve in the steering makes for a lot of sloop in the steering. Rack and pinion use the same kind of system - but it looks like a lot less play, so it may be nothing - that said, I'd hate to put this all together and find out that, while it does a nice job centering, it does a terrible job and being neutral on the road.
  #397
Old 09-14-2018, 08:52 PM
rtj's Avatar
My Photos: (58)
Found it again. See photo.
  #398
Old 09-14-2018, 09:08 PM
BBShark's Avatar
My Photos: (264)
Is there a manual steering option for a C5? I wouldn't think so.
Some people are running the Grand Am rack on C3's without a pump and no issues. It probably wouldn't be great for parking lot maneuvering but you probably won't be doing that.
  #399
Old 09-18-2018, 04:21 PM
My Photos: (0)
so the next step will either be gold or goat.edited I'm going to put Camaro rotors and Camaro Brembo brakes (basically rely on the design of GM).... will it work?edited dunno
I know I can make it work and I know that I'll have to build adapter brackets.... but here's the deal - Detroit Speed suspension is 18,000-23,000 and I may have 2k in this suspension with the new coilovers..... that's front/rear price.... wish me luck
as for the rack - I'm going with a stock C5. There is a drag-race manual rack available for about $500 but it states no street use - which could be an anti-lawyer device or could be it's not designed for high-lateral-g loads.... I'd rather not bet when it comes to that. Thus either I'll make the C5 steering manual (with the bypass line) or I may put a pump on and have hydraboost brakes as well. That said, I may make the steering true manual by converting the stock, C5 rack
  #400
Old 09-18-2018, 06:11 PM
bobs77vet's Avatar
My Photos: (2)
i like the C5 rack on my C5 and i liked the steeroids rack on the C3 (i think that was the grandam rack), i did have to play with the shims in the pump on the C3 to get the pressure right.
I think it would be hard to argue against the c5 rack as a good choice, can you use all the speed sensitivity steering stuff as well that the c5 has?? i guess the power steering pump pressure is reduced as the speed goes up.
