  #1
Old 11-01-2018, 02:07 AM
69427's Avatar
69427 69427 is offline
My Photos: (0)
Default Power steering cooler plumbing questions.
I'm planning on finally putting a cooler in the system over the winter. I'm not a big fan of the normal cooler placement (downstream of the rack), as it just seems like the fluid gets all heated up in the pump while driving down the straights, and then the hot fluid gets sent straight to the rack, and after heating up the rack it gets sent through the cooler. This all seems incredibly inefficient (regarding trying to keep the rack cool).
I'm curious. What would be the downside(s) to putting a Tee fitting in the pump outlet, with one line going straight to the rack, and the other line (with a small pressure-dropping orifice at the Tee fitting outlet) running to the p/s cooler in front of the radiator? This would keep the normal path for fluid to the rack, for normal steering operation, but the extra loop would allow a continuous flow of the hot fluid through the cooler, allowing heat to continually be removed. (There would obviously be two return lines going back to the pump reservoir.
One downside is that there are now twice as many lines to possibly leak. Another is that there would possibly be some loss of steering boost/assist, depending on how much fluid is shunted to the cooler line. Are there others I'm not recognizing at the moment?
Thanks for any constructive input.
  #2
Old 11-01-2018, 09:33 AM
phantomjock's Avatar
My Photos: (632)
Dump the PS and get a Steering Quickener?
Just thinking...
No pump, No Belt, No cooler.
Rebuilder's Zen Saying:
  #3
Old 11-01-2018, 03:12 PM
69427's Avatar
My Photos: (0)
Quote:
Just thinking...
Well, the steering is already quite quick. It's the low speed effort I don't care for. I believe a quickener would just increase the effort.
Another idea I'm curious about, but don't know if it's possible, would be to tap into the pressure regulator/relief portion of the pump, and when the relief valve is opening (as in straightline times) than the relief volume would go to the cooler, but during cornering when there is actual flow out of the pump, the relief flow to the cooler would reduce/stop temporarily.
  #4
Old 11-02-2018, 01:45 AM
vette427sbc's Avatar
My Photos: (0)
I'm not sure if this falls outside of your OEM appearance preference, but what about an electric hydraulic pump?
ill be running a Mercedes A-Class pump in my car... standalone unit, so simple power and ground hookups, pressure on demand means it won't be generating heat and drag when I'm at 6kRPM going straight. Smaller cooler, less weight, less fluid, and full pressure at idle for parking lots, etc...
seems to be a popular pump for the Porsche GT club cars that run sticky tires and aero.
Chris
AutoWorks Middletown NJ
@autoworksnj
  #5
Old 11-02-2018, 02:52 AM
69427's Avatar
My Photos: (0)
I'm open to alternatives. I'll confess I'm not up to speed on the details of an electric pump. Off the top of my head: What's the weight of the pump? What's the current draw (Is a bigger heavier alternator needed to provide enough current when the car is in a consistently twisty part of the track?)
My goal is almost always lighter weight, rather than any net horsepower gain. I can keep up with most cars on the straights (and usually braking too), but I'm (self) limited to 11.75" rotors and 8" wide tires (I'm running 15" wheels). I've got 10-20% less vehicle weight than most guys out on the track, but I'm often running with 30% less tire width, hence my "obsession" with weight reduction.
  #6
Old 11-02-2018, 05:09 PM
My Photos: (0)
The fuse in the Benz is 80A... I would think that speeds above 40mph the pump would be barely running (other benefit is you could turn it off completely at >xMPH) I could see an auto-x giving the pump and alternator a workout, but from what Ive read it seems like these are pretty robust pumps, mechanically speaking. Being that theres an electric motor driving this pump, I wouldnt be surprised if it was over 10lbs...
  #7
Old 11-13-2018, 02:41 AM
My Photos: (0)
8.4lbs is the dry weight according to the guys over at the porsche forums... I just put an offer in on one on ebay.uk...
