Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #51
Old 02-20-2017, 11:54 AM
OZgreen69 OZgreen69 is offline
Australia | Addict
My Photos: (125)
Default
Nice to see. Looks like we are both "improving" our chassis at the same time!
  #52
Old 02-20-2017, 06:59 PM
1Michel 1Michel is offline
Canada | Addict
My Photos: (494)
Default
Quote:
Originally Posted by rtj View Post
The all thread held the two weld in nuts in alignment far better than I expected. The center bolt went right into place. Welds leave a lot to be desired, but the plan is to replace the frame in the next year or two. I'll have better access on a bare frame and hopefully have a Miller or Lincoln tig.
I'm not sure how this is working, could you pls explain?
I understand that it will replace the shims but not sure how.
__________________
Eat dessert first! life's unexpected!
  #53
Old 02-20-2017, 09:27 PM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (17)
Default
Sure. No shims are used. I put on my trailing arms with no leaf spring using the long thin grade 8 bolt at ride height. I attached a laser level to the brake disk (secured by lug nuts). With every thing installed and torqued up (except the spring), you slowly tighten up the 3/4 in bolts. I basically aligned the back wheels parallel to the frame. I made the bolts snug and used lock nuts to lock them in place. Lastly, the thin bolt is tightened up and locked with double nuts.
Welding that with the body on and no lift is a b_____! My welding skills aren't too good and even worse when laying down.
I might have added washers between the 3/4" bolts and the TA bushing, I don't remember. I did clean up the bolt end in the lathe.
The frame I'm working on now will have 2 positions, stock and raised 1 " or 1.5 ". My plan is to make a plate and weld in nuts or thread it, then weld the plates to the frame. I'll post some results in a month or two.
  #54
Old 02-20-2017, 09:36 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
The idea was to strengthen the TA attachment. OEM basically loads the bolt in bending and shear across the full inside width. With the 3/4 " bolts the through bolt is mostly in shear, minimal bending.
  #55
Old 04-12-2017, 11:59 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
I hacked the flares off the 75 ( photos pages back) and was thinking I'd do something similar to this article. I'll add 1-1.25 inches width with metal straps, then fiberglass and foam to get them finished. The Mud-flap will probably get rounded off at the same time.
I may put this frame under the 75 and find a nicer one for the convertible body. The 75 is so hacked up now, it might be good for practice.
  #56
Old 04-13-2017, 11:56 AM
BBShark's Avatar
BBShark BBShark is offline
United States | All About VetteMOD
My Photos: (242)
Default
That is a very nicely done adjuster. Wish I had done that.
__________________
  #57
Old 04-14-2017, 02:03 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
Seems pretty solid, haven't put a lot of miles on it.
I think I've finalized a new design which will give a choice between stock and 1 to 1.5 in drop. Will have a similar adjustment for the rear mount and pinion bracket.
The 75 is pretty beat, so it's a good car to experiment on.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
