Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #11
Old 02-07-2017, 01:14 AM
odies dad odies dad is offline
United States | n00b
My Photos: (0)
Default
I finally got this picture to load.
  #12
Old 02-07-2017, 02:32 AM
mfain's Avatar
mfain mfain is offline
United States | Addict
My Photos: (6)
Default
Quote:
Looks good. I would position the rear end with the axle yolks 13 inches above the ground (or whatever your tire radius is), then put the frame rails at your desired ride height and see how the mounting ends of the batwing match up with the frame rail. Since the batwing appears to be wider than the frame rails, you may end up having to do some modifying of the rear frame rails where the batwing mounts will be to get the right geometry. I would also make the forward links longer than the existing C4 dog bones - you have plenty of room. Consider having the front pick-up points of the forward links adjustable - i.e., multiple holes for each link much as most four link set-us have.
Pappy
__________________
Pappy
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
