  #1
Old 08-14-2019, 09:32 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (178)
Default About dual master cylinder.
Thanks Chris, here is my work on your idea.
I am not sure what is more work ? This or fitting a Tilton a floor mounted pedal box ??
  #2
Old 08-15-2019, 01:51 AM
vette427sbc's Avatar
My Photos: (100)
Looks great! I would have done the floor mount if I had a later steel floor car... too much flex to mount in the ‘glass and probably more work/additional weight to make it sturdy enough.
What did you end up making your pedal ratio?
Chris
AutoWorks Middletown NJ
@autoworksnj
  #3
Old 08-16-2019, 12:13 AM
rtj's Avatar
rtj rtj is online now
My Photos: (71)
I have some photos some where of the floor mount pedal install. They cut out a chunk of the floor/firewall and bonded in a box/foot-well. It looked nice, I’ll see if I can find it.
This method by vette427sbc is probably better. Especially when you are vintage racing.
  #4
Old 08-16-2019, 09:02 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (178)
I choose the 5 to 1 ratio, 5.15 to be exact.
And I was thinking more of a pedal box like this one:
I hope that my choice of M/C and set up is right, because it will be a pain to go behind the steering column to change them. You may understand why I want to do something about the column ! Will see...
  #5
Old 08-16-2019, 04:30 PM
rtj's Avatar
My Photos: (71)
I hope that my choice of M/C and set up is right, because it will be a pain to go behind the steering column to change them..
You can buy a remote adjuster.
  #6
Old 08-16-2019, 09:48 PM
rtj's Avatar
My Photos: (71)
I found it. Photo 49, 50,and 51. Pretty clean install, but pricier as you have to install a hydraulic clutch system too.
  #7
Old 08-17-2019, 11:05 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (178)
Thanks ! Nice car and good ideas !
I like this foot well installation if you are not running side pipes, I fear that the master cylinders will get hot even with some insulation !
My choice was the model with the master cylinders underfoot like the Tilton 600 series as I have hydro clutch already.
And yes I have a Tilton balance bar adjuster.
  #8
Old 08-19-2019, 08:46 PM
My Photos: (100)
Lots of cool tricks on that car... had never seen it before. 180* Sidepipes
  #9
Old 08-19-2019, 08:54 PM
My Photos: (100)
I think its a column-out kind of job!
What size masters? Looks like 7/8 from the pics but I cant be sure...
did you do any calcs to change your psi at the calipers? I couldnt find the thread where you felt the pedal wasnt right... too hard or too soft. I bet the cast iron calipers can take alot of PSI before spreading like the wilwood and other alu variants
  #10
Old 08-20-2019, 10:07 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (178)
3/4 and 7/8 Master cylinders.
I always found the pedal travel too long for heel and toe and I don't mind to have a harder pedal . For the street this is another story you may prefer a longer travel.
Yes, the travel is my problem, especially when you need to pump the brake pads after a chicane !
And about the quality of the factory caliper ? You will be surprised at how much they can spread open !! This is why I have a bridge on mine [Only registered and activated users can see links. Click Here To Register...]
This and the flex at the stamped bracket !!
