MYBAD79
Moderator
I finally started on my front flare installation. Here are the flares as I received them from Vanacor, these are the 1.5" wide L88 flares for the front to match the 2" wide flares on the rear.... no more mudflap... :waxer:
These are photos of todays first "test fitting" after I cut the stock '79 fender lip and mudflare off.
The fit is as good as the rear flares, I am actually positively surprised with the quality and fit... like with all fiberglass pieces, some cutting and fitting is required..... it's not a simple 'bolt on' or 'glue on' job.... if you want to get this to fit and look perfect then it takes some work. I have already worked on this for four hours today and I am nowhere near ready for adhesive... and I only did one side so far.... :rain:
