New Project
I know all to well how that goes. Are you just detailing under the hood or is there other plans in store?
Rebuild every thing that needs it
Steering box and columm
Assisted steering complete
350 30 over
Flat top pistons
202 valves
700r4
A arms
Heater core
A/C
Interior complete
Then the rear suspenison
Good thing I have another vette to drive while this one is down.
So I'm NOT the only one addicted to crack :lol:
Got just a little bit of work ahead of you there - perfect opportunity to do some powder coating though :thumbs:
Starting over again....ain't it a blast!
Looks like someone was in there welding on the lower control arm bracket.
Yep matches some of the other things I have found. That will be ground and rewelded. I guess it hit a curb and that a arm was replaced.
But still finding the vacuum tank 3/4 full of mud and water and having only calif rust is a mystery.
those welds are ugly.... better grind all of that out and re-weld. Now that the engine is out of your way I'd weld the entire frame - those stitch welds from the factory are a joke at best...
Look under the cross member and check the A-arm channel.... those things often seperate from the crossmember....
