welding a C4 frame section to a C3 frame & finding center points
JeffP1167
Yucaipa, CA.
I have heard conflicting statements to the effect you can't weld a c4 corvette front frame section to a c3 frame due to the different material. Yet I have seen fiero's stretched using regular steel to stretch what appears to be the same kind of metal the c4 frame is made of.
Also how do you center the suspension using GM guide holes or whatever they used when the cars were built?
This guy obviously did this but I don't know who it was, so apparently it can be done.
I'm sure Marck will read this at some point ... So what did you do to center your suspension swaps on your 82?
