X-ram, 2" injectors, NOS= HP.
Joe Dirt
Active member
Kootenay
How much HP will this combo produce? The x-ram looks like it can flow alot of air. Is NOS better suited with the x-ram or the old stock intake? I'm thinking that extra air with the NOS would produce more power and with a higher stall converter should do the trick along with 3.75 gears.
The x-ram, the newer one you can adjust the valves with it installed, it is going on an 84 vette.
Really depends, the lower portion of the X-ram is a Weiand Stealth intake, the X ram plenum is pretty shallow. If you could space it up it could be a nice setup.
Nitrous won't matter much which intake you use, X-ram has not been proven to have much gain over ported stock. I seem to recall that on a bone stock 84 it gained 7HP but lost a bunch of low end TQ w/ an X-Ram.
