Go Back   VetteMOD.com > VetteMOD Technical Discussion > Classic Corvettes
Reply
Thread Tools
  #1
Old 03-14-2018, 11:44 AM
OZgreen69's Avatar
OZgreen69 OZgreen69 is offline
Australia | Addict
My Photos: (162)
Default Hood support/stay
On my non original hood, the mounting point for the support is lower than the factory one ! Would you know if a 72/73 support/stay would work.
I tried to modify the original sliding support, but the geometry is different due to the lower, upper mount. So maybe a scissor action like the 72 could work if shorter?
[Only registered and activated users can see links. Click Here To Register...] Yellow trace is the original mounting point. Black the present one.
  #2
Old 03-14-2018, 02:03 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (266)
Default
This might be a solution:
__________________
  #3
Old 03-14-2018, 03:02 PM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (60)
Default
I fixed a hood with this issue by the following:
Drilled two new holes where needed.
Cut hole in hollow structural fiberglass near windshield.
Drilled and tapped two holes in 1/4 steel.
Slid steel down to location and bolted it up.
If you leave the hood on, tie some string or wire on your steel backing plate. You could drill extra holes for epoxy.
I’ve also used nutserts on another hood.
  #4
Old 03-15-2018, 09:17 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (162)
Default
Thanks BB and RTJ,
That give me some ideas! Appreciated.
  #5
Old 03-15-2018, 09:47 PM
Grampy Grampy is offline
My Photos: (3)
Default gas struts
I converted to a gas strut. They come in many lengths and spring rates to adapt to your changed geometry. They are lighter than stock piece and all the mounting hardware is readily available. These things are used a lot on campers and boats as well so many sources. Just search web for gas springs or gas struts.
Grampy
  #6
Old 03-16-2018, 01:22 AM
69427's Avatar
69427 69427 is offline
United States | The Artist formerly known as Turbo84
My Photos: (2)
Default
I swapped out my original hood support for a couple pieces I fab'd (to take a few ounces off from up front and up high). I made a prop rod from quarter inch diameter solid rod, welded a ring on one end that bolts to a pivot point on the hood where the original support bolted up, and then formed an aluminum piece that bolts to the fender where the original support bolted to. The prop rod has a short 90 degree bend on the lower end that fits into a hole in the lower aluminum bracket when holding up the hood. The same basic function as in a lot of newer cars, and this setup was slightly lighter than the stock support.
  #7
Old 03-18-2018, 06:55 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (162)
Default
Thanks Gents, in fact I duplicated the factory one . I had that solution in front of my eyes but went blind instead !! A few sweaty minutes lowering the new plate and pop riveting it place !!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
