Go Back   VetteMOD.com > VetteMOD Workshop > Shop, Tools and Equipment
Reply
Thread Tools
  #1
Old 09-07-2013, 06:07 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
United States | Addict
My Photos: (0)
Default Not as fancy as some of the cool toys I see here...
...but I found a nice 110V US-made ESAB plasma cutter with built-in air supply at a local electronic salvage store. Got out the door with it for $225. Just need a new electrode and it'll be ready to go!
  #2
Old 09-17-2013, 03:40 PM
84rzv500r's Avatar
84rzv500r 84rzv500r is offline
United States | Knows just enough to be dangerous!
My Photos: (105)
Default
you will like...
I have a larger 220V Hobart unit that We used to build a 3 axis CNC Plasma cutter from... it will do 0.5" steel all day
and a little 110/220 Miller unit for the shop that runs out of ass at anything over .375 or so but its great for portability and sheet metal...
__________________
1971 Can-Am, 502 Ramjet, CC Rollers, hookers, 14 pt cage, Lakewood, McLeod RST DD, ROD 6 trans, 3.08 rear, Wilwood brakes, Hydraboost, Steeroids, Tubular A-arms, QA1 DA and Viking DA shocks, VanSteel HD offset TA's w/Johnny Joints, 6 link, 3" tele halfshafts, modded dragvette loops, 16 gallon fuel cell, basset wheels 15x10x4 with nitto 555r 275/50VR15, 15x12x4.5 with nitto 555r 325/50VR15's, Ultrashield seats, SW Clocks, 16" spal fan, Jones Racing RTP, FIA lights, Mirrors, Action...
  #3
Old 09-17-2013, 05:41 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Quote:
Use a gun??? Nice score!!!
__________________
  #4
Old 03-28-2016, 12:31 AM
Sam Cogley's Avatar
My Photos: (0)
Default
2.5 years of futzing with this thing on and off, and I finally figured out why it wouldn't form a proper cutting plasma arc, which is why it ended up at the electronics recycler in the first place. There is a brass compression fitting where the air hose connects to the head assembly, buried deep inside the handle structure. That stupid fitting was loose, causing it to bleed air pressure like crazy - but I never felt the leak, since it was just blowing out of the back of the handle. Tightened that up, and it works perfectly.
I feel like kind of a dunce that it took so long to find something as silly as a loose air fitting, even if it was in a rather difficult place to locate.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
