Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #11
Old 09-04-2018, 09:28 PM
SRountree's Avatar
SRountree SRountree is offline
United States | Addict
My Photos: (105)
Default
i found this oil pan at summit
it will work but I will check my measurments to make sure. (and call FR)
making a small dent may work too... lol
__________________
Steve Rountree
513.505.4494
Middletown OH
If you can change your thoughts,...
You can change your world...
  #12
Old 01-27-2019, 01:24 AM
SRountree's Avatar
My Photos: (105)
Default
Flaming river was not much help so I stopped working on my vette until tonight.
I bought a couple shims to raise the engine about 3/8", I mocked up the cradle with the rack and pinion to make sure I was ok on the clearance. So far so good, everything clears with about 1/4" to spare.
Hopefully I'll have time tomorrow to work on tightening everything up and installing the stearing linkage.
  #13
Old 02-26-2019, 01:43 AM
SRountree's Avatar
My Photos: (105)
Default
Got the FR R&P in and tighten up. Everything went in smooth. Have full turning radius and it's tight. I'm installing a serpentine drive system, electric fans, and I'll drive it to the shop to get an alignment done.
The FR instructions weren't very clear and I couldn't find anything on you tube that was up to date. With that being said, the steering is really smooth. It's an expensive system but hopefully it will be worth it.
  #14
Old 02-26-2019, 10:28 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (299)
Default
Got any pictures?
Is the Flaming River setup power or manual?
__________________
  #15
Old 02-27-2019, 01:36 AM
SRountree's Avatar
My Photos: (105)
Default
The system I bought is a power system and yes I took a lot of pictures because there isn't much on the assembly. Is there an easy way to upload the photos?
  #16
Old 03-27-2019, 06:22 PM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
Got the pan clearance figured out ? If your oil dipstick is on the passenger side then I have a stock style oil pan that I had on my 383 before I installed a 7qt pan, send a PM if you want it.
__________________
Link to my garage:
  #17
Old 03-28-2019, 11:25 PM
SRountree's Avatar
My Photos: (105)
Default
Hey I appreciate that but I ended up using a couple of shims on the motor mounts raising it enough for the clearance I needed. It worked out great. My dip stick is on the drivers side though.
If anyone wants to know about the Flaming River install on the C3, I took better photos so you can see how nice it is. It was expensive but worth it. I'll get the photos posted soon with more details. I really like the cradle system. I have yet to drive it... lol soon though...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
