Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #11
Old 04-24-2019, 11:17 PM
69427's Avatar
69427 69427 is offline
United States | The Artist formerly known as Turbo84
My Photos: (2)
Default
Quote:
Originally Posted by COLE SWEAT View Post
I flipped the shocks on a lowered 05 express van, it helped on the rebound but the dive was worse
Why use c4 front control arms?
A C4 suspension is about half the weight of a C3 suspension, the front spring anchor position on the LCAs are farther out (ie: better), coilover springs are lighter than C3 springs, a complete C4 suspension is pretty inexpensive, and I like the looks of a factory aluminum suspension (my looks reasonably stock to the casual eye).
  #12
Old 04-25-2019, 03:17 PM
Kacyc3's Avatar
Kacyc3 Kacyc3 is offline
United States | Member
My Photos: (0)
Default
Quote:
Originally Posted by 69427 View Post
I'm currently modifying the UCA mounts to allow a bit more dynamic caster and camber. While I've got things apart I'm kicking around running the coilovers upside down (if it will package worth a darn). They're gas shocks, so the position shouldn't be an issue (correct me if I'm wrong), and there ought to be a slight reduction in unsprung weight in the process.
Outside of a bit more possible debris hitting the ram/shaft of the shock due to its lower position (possibly a protective sock of sort might be a good idea), I'm just looking for any ideas of problems that I haven't thought of yet.
Thanks for any constructive input.
Your theory is sound, they inverted the shocks on crotch rockets to improve handling. I am willing to bet that aside from mounting issues stock shocks/coil overs wont function correctly inverted and may require locating some that are designed to work inverted..would it be worth the expense?
__________________
Cheap
Fast
Reliable
You only get to choose 2.
  #13
Old 04-28-2019, 11:58 PM
69427's Avatar
My Photos: (2)
Default
I don't have a good answer about that. I've read in magazine articles before that gas shocks will work fine upside down, but I've never tried it.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
