Go Back   VetteMOD.com > VetteMOD Technical Discussion > EFI
  #1
Old 06-21-2014, 02:01 PM
Belgian1979vette's Avatar
Belgium | Addict
My Photos: (104)
Default fire in the hole, but some fuel pump questions
Well, after a lot of issues and wiring problems yesterday I finally succeeded in firing up the engine on megasquirt FI.
Not even difficult to start, which, I guess, is a good sign.
BUT : my Aeromotive A1000 is one loud MF. I use a surge tank, with a Holley HP125 pump supplying the surge tank and then the A1000 supplying the high pressure. All pumps are well below the level of either fuel tank or surge tank, so that's not the issue. Fuel lines are large enough so that's not a problem either.
But the Aeromotive is so loud I'm not going to leave it in there.
Would like some suggestions on a good pump with some 400 lbs/hr flow at 45 psi pressure and silent...
Input is appreciated.
Opinions are like assholes, everyone has got one, but everyone thinks everyone else's stinks.
  #2
Old 06-21-2014, 02:26 PM
Twin_Turbo's Avatar
Twin_Turbo Twin_Turbo is offline
Netherlands | Der Maulwurf
My Photos: (1296)
shoot a vid, it's not that loud normally... aeration/cavitation makes them very loud. You will need at least a -10 line on either side, period. Same for filters, -10 or larger. If your rails are -6 or -8 run them split parrallel and use a regulator with a -10 return.
  #3
Old 06-21-2014, 04:26 PM
Belgium | Addict
My Photos: (104)
I'm out for the moment because I'm doing work on the fuel system.
The pump has all -10 in and out lines. The filter is the proprietary Aeromotive filter with -10 in and outlet. The bypass is also the proprietary Aermotive with -10 inlets and a -6 return. Pump is lower than the surge tank so it should feed the pump all by itself.
Not sure what's going on.
  #4
Old 06-21-2014, 05:10 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
You say the pump is noisey?? how do you have it mounted?? I tied my FI pump to the rear frame rail with nothing but a hose section wrapped around it for sound deadening, and a hose clamp to the frame, so essentially it's mounted in rubber, cuts lots of noise down.....
  #5
Old 06-21-2014, 09:21 PM
Belgium | Addict
My Photos: (104)
the sound in this clip is similar.
Its mounted in the front of the feet of the passenger on the firewall. Only spot up front I could mount it.
  #6
Old 06-21-2014, 10:17 PM
mrvette's Avatar
My Photos: (3)
WHY up front??? like mine, it's a FI pump, and so mount it on the REAR frame with rubber isolation....but mine is a cheap parts house thing, about 2" round and 6" long.....suction on one end, and output and electric on the other end....and certainly not near that amount of noise....no where NEAR even if mounted on a sounding board....
  #7
Old 06-22-2014, 08:47 AM
Belgium | Addict
My Photos: (104)
Gene, I didn't want to mess with air getting in the lines leaning out fuel on top and melting pistons or so. I couldn't modify my stock tank since it is the bladder tank, which is why I'm using a surge tank. Only place I could mount it was in the right fender. Pump needs to be lower than the surge tank, so not a lot of options there.
Seriously considering taking it out and using a Holley 12-1400 dominator in its place. They say it's silent, but that was said about the A1000 as well....
  #8
Old 06-22-2014, 11:39 AM
mrvette's Avatar
My Photos: (3)
I just have a batch fire L98 setup, 355" and roller cam....essentially a ZZ4 engine, since my car was a '72 the tank had no bladder in it, and it was replaced by previous owners, I too have a 'surge tank' mounted up front and lower than the main tank, my reason for it was to keep the fuel flowing in a turn when the tank got near empty, engine would die/buck/surge soon as the fuel sloshed to one side, so I got a steel 5 gallon air tank and mounted it forward of main tank and lower, return line goes to the surge tank, main tank drains into surge tank, pump takes fuel from bottom of surge tank, I have a locking vented cap, and a more or less stock evap emissions charcoal canister with that black plastic float valve on the left/forward side of the main tank.....
I WAS getting some fuel smells in the garage when tank was full, but at only 50% full there was none....I was scratching my ass but good over that one, finally pulling the rubber rain boot off the filler neck, and found the leak, it was some odd looking fitting off to the left on top of the tank, I cleaned it off and poured epoxy all over it, never an issue since then.....
I even have the fuel filter on the suction side of the pump, and use the stock 3/8 - 5/16? lines for supply and return, not ever an issue in spite of all the guys saying otherwise.....
  #9
Old 06-22-2014, 12:12 PM
Belgium | Addict
My Photos: (104)
Where in God's name did you mount a 5 Gallon tank ?
  #10
Old 06-22-2014, 04:58 PM
mrvette's Avatar
My Photos: (3)
OH, forgot to mention...no spare tire/carrier...some steel was welded to the air tank, and goes forward to the old carrier bolt position, and the handle of the tank is bolted to the main fuel tank brace.....
