Go Back   VetteMOD.com > VetteMOD Technical Discussion > Modern Corvettes
  #1
Old 09-19-2015, 11:58 PM
69427's Avatar
69427 69427 is offline
My Photos: (3)
Default Rear spring spacer/insulator question.
Anyone know the specifics of what the spring insulator material is between the batwing and the spacers above the spring? I don't have either the spacers or the insulators, but the spacers look easy enough to fabricate. I'm mainly curious what the insulators are. I've kicked around using some stainless shims for insulation, but I'm just curious what the factory used.
Any help is appreciated. Thanks.
  #2
Old 09-20-2015, 10:16 PM
Kid Vette's Avatar
Kid Vette Kid Vette is offline
United States | Master-Baiter
My Photos: (315)
What year are you referring to? Fiberglass spring?
“Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.” Colin Chapman
  #3
Old 09-21-2015, 01:35 AM
69427's Avatar
My Photos: (3)
Quote:
C4 batwing and spring.
  #4
Old 09-21-2015, 07:55 PM
69427's Avatar
My Photos: (3)
Apparently, if I understand correctly, whatever the original insulator shim was it's no longer available. So, any suggestions for a somewhat durable material that will withstand the compression of being sandwiched between two pieces of aluminum (the batwing flange and the spacer)? Stainless steel is my fallback material if something better doesn't pop up.
Thanks.
  #5
Old 09-21-2015, 11:04 PM
bazza6977 bazza6977 is offline
Australia | Member
My Photos: (0)
when you buy a VB and P fibreglass spring for a C3 you get two pieces of a black plastic to replace the thickness of an original steel spring . One goes hard up against the bottom of the diff housing so they must be ok with the heat .
I would try maybe seeing if vb and p could sell you some or at least try to find the equivalent ???
its way lighter than stainless !!!!!
  #6
Old 09-22-2015, 01:35 AM
69427's Avatar
My Photos: (3)
Well, the two stainless shims are only going to be 1" x 2", and about .060" to .080" thick. Ounces at the most.
  #7
Old 09-22-2015, 12:52 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
The VBP urethane spacer on top of my VBP plastic spring is about 1/2" thick and 4-5" long and about 4" wide sounds like just cut one in 1/2 and done....
  #8
Old 09-28-2015, 12:55 AM
69427's Avatar
My Photos: (3)
Quote:
It's a C4 batwing and spring. Not a C3. Apples and oranges.
  #9
Old 10-16-2015, 12:24 AM
69427's Avatar
My Photos: (3)
Finally occurred to me that I've got some insulators in the C4 suspension under my '51 Chevy pickup. The truck's torn apart at the moment so I decided to borrow these parts, and just replace them (with something) down the road. The insulating material looks similar to bakelite, or something along those lines.
  #10
Old 08-25-2020, 07:54 PM
69427's Avatar
My Photos: (3)
Default Additional thermal resistance?
I'm doing some rearranging of the rear spring aluminum spacers seen in the picture in the above post. While I've got them out, I'd like to somehow increase the thermal resistance/insulation of the shims. I've thought of giving them a coat of flat black barbeque grill paint, top and bottom, to give several interface layers of reduced heat conduction ability. I'm open to other better suggestions though. I'd like to hear other ideas if available.
Thanks,
Mike
