Go Back   VetteMOD.com > VetteMOD Technical Discussion > Paint, Body and Interior
  #41
Old 02-07-2010, 09:51 PM
saudivette's Avatar
saudivette saudivette is offline
Australia | Clueless In Sandland
My Photos: (334)
Quote:
Originally Posted by TimAT View Post
Get some PRC...
B 1/2 sound ok?
Understeer: when you hit the wall with the front of the car.
Oversteer: when you hit the wall with the back of the car.
Horsepower: how fast you hit the wall.
Torque: how far you take the wall with you.
Wayne Of Arabia,
Sand Happy
----->[Only registered and activated users can see links. Click Here To Register...]<-----
  #42
Old 02-07-2010, 11:13 PM
SMYDA's Avatar
SMYDA SMYDA is offline
United States | Knuckle Dragger
My Photos: (0)
Quote:
Originally Posted by saudivette View Post
I will be sticking my frames back to the tops soon but what should I use to do it? I spoke to a T-top rebuilding place some time ago and they said that they use urethane adhesive when sticking glass tops back onto the frames but obviously they had no experience with steel tops. Would urethane adhesive be ok to stick my steel tops back on?
Saudi ... it will work fine. Be sure to use the pinch-weld primer on the metal
before applying the urethane. Think about this logically .... a windshield is
glued to a steel pinch-weld so why can't the opposite also work ...
The Pinch-weld primer is intended to be applied to bare metal .. then apply
the urethane ... I would recommend you use a High Viscosity Urethane like
that used on modern car windshields.
