Go Back   VetteMOD.com > VetteMOD Workshop > Restoration Techniques
  #11
Old 10-02-2009, 12:46 AM
1Michel 1Michel is offline
Canada | Addict
My Photos: (494)
I tried it on a clutch housing with the plate, it was mostly surface rust.
Dunked it in a rubbermaid bucket and added some baking soda and pluged it.
Checked on it after about 1/2 hour the rust was coming off.
forgot about it for the night and next morning the thing was pretty damn clean.
I was impressed.
Eat dessert first! life's unexpected!
  #12
Old 10-02-2009, 10:13 PM
AColbe01's Avatar
AColbe01 AColbe01 is offline
United States | Member
My Photos: (12)
Also check out about Hydrogen embrittlemnt(sp?) as a result and heating material afterwards to remove.
Interesting stuff, but big no-no to use stainless steel.
Andy
Just about the time I think I can get the ends to meet someone moves the ends!
  #13
Old 10-06-2009, 06:29 PM
DWncchs's Avatar
DWncchs DWncchs is offline
My Photos: (0)
I'm using a power source from an old cordless phone. 9v 450ma It seems to be doing a good job and it shouldn't be using near the power of my regular car charger. My car charger is a little noisy as this is silent. Who doesn't have a box of these little chargers laying around.
  #14
Old 10-19-2009, 02:38 AM
68/70Vette 68/70Vette is offline
My Photos: (0)
I've de-rusted quite a few parts for my 68 and 70 Corvette projects.
For parts like rear wheel spindle assemblies where I didn't want to destroy machine dimensions (bearing inserts), I used vinegar. It's active ingredient is acetic acid. Vinegar is about 5% acid and the acetic acid is very gentle. It removes rust. It takes a day or so. When you dunk your parts in vinegar, within a few minutes you can see little bubbles forming on the metal. The bubbles are hydrogen gas and you know the vinegar is working. The great thing about vinegar is that you can dunk you hands in it without worry.
I use cardboard boxes, tape several together, and then fiberglass line the inside of the boxes to make my acid soaking vats. It's expensive. I've spent pretty close to $100 for fiberglass and resin making a soaking vat.
For more aggressive de-rusting where accurate machine dimensions are not a worry(transmission crossmember, front first most crossmember), I use hydrochloric acid (muratic acid). Plumbing supply stores sell it. I usually dilute it enough so that i can put my hands in safely. It's dilute, but I can often feel a little sting, so I can quickly wash my hands off. It causes an active bubbling (foaming).
If you've got a cad plated part that's become ugly with age, just dunk it in hydrochloric acid and it'll immediately take off the cad plating.
I'll have to check with my plater, but I think hydrochloric acid takes off chrome, but it doesn't take off nickel. Maybe I've got it backward???
Anyhow, electrolysis is not always needed.
  #15
Old 10-19-2009, 12:41 PM
DWncchs's Avatar
My Photos: (0)
Quote:
But it sounds like it might be cheaper.
  #16
Old 10-20-2009, 10:05 AM
phantomjock's Avatar
My Photos: (663)
Hey Guys!
Very cool approach. Wonder if you have an idea for internal rust?
A bolt (last one of course) is ABSOLUTELY STUCK on my front wheel holding the brake caliper on.
I have use so far:
1. Heat -- just got hot and smoked
2. Kroil Oil -- good stuff -- usually but no go
3. PB Blaster --- this has been the ticket in the past -- no show
4. Truning in -- wouldn't budge that way either,
5. PB Soaking --several days now -- still stuck
6. Heat around the bolt, frezze-on the bolt -- still stuck
Now, I'm just about out of ideas. Was wondering if maybe electrocuting the sumbuitch might shock it into submission. Gotta come up with someting before the head is totally rounded off (yes using 6 sided socket.)
Maybe drill a hole in the center and try and collapse the bolt? I get the idea maybe a twist out would twist off from how stuck it seams.
HELP!
Rebuilder's Zen Saying:
  #17
Old 10-20-2009, 03:05 PM
DWncchs's Avatar
My Photos: (0)
Quote:
Originally Posted by phantomjock View Post
Hey Guys!
I have use so far:
HELP!
Heat the caliper where the bolt goes into it not the bolt.
Use an impact wrench.
Usually on the caliper side there is a small hole where the end of the bolt comes through,maybe spraying PB in the hole will help.
  #18
Old 10-29-2009, 11:36 PM
My Photos: (0)
Have you tried an impact wrench. I've had suspension component bolts that didn't want to turn with a straight bar wrench. When I used the impact wrench, they spun right out.
Another good aspect of impact wrenches are that I believe they are generally less prone to rounding off the bolt head. I think the jarring impacts are the key reason these wrenches can be so effective loosing bolts.
......and a possible downer. It is possible for the impact wrench to snap the head of the bolt off.
  #19
Old 12-03-2009, 06:33 PM
1981Z06Vette's Avatar
1981Z06Vette 1981Z06Vette is offline
My Photos: (0)
I have had good luck using vinegar myself...its great on pitted, but otherwise good sheetmetal, and for rusty tools. I'll have to try the electroysis method sometime, thanks for sharing!
Joe Hinds- Bulldawg MuscleCars
1981 Corvette (under construction) LQ4 6.0 stroker/T56
