Go Back   VetteMOD.com > VetteMOD Technical Discussion > Electrical & Ignition
Reply
Thread Tools
  #21
Old 02-20-2012, 03:36 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
Quote:
Originally Posted by redvetracr View Post
that starter looks like a knockoff of this one....I had the nose changed to use on my vintage racer with a 153t flexplate but never did. $100 owns mine (genuine GM and only started my racer two times, I switched to a reverse drive starter and 5.5" clutch)
it does doesn't it?...with some differences, that gm one does not have plastic junk inside and a reinforced nose (ribs), I have broken 2 of those chinese starters (I didn't buy them, they came on the cars) and 1 was the spin gear set, the other cracked the nose.
__________________
  #22
Old 06-16-2012, 01:15 AM
Kid Vette's Avatar
Kid Vette Kid Vette is offline
United States | Master-Baiter
My Photos: (314)
Default
Well, I finally discovered that GM makes starter bolts to adapt these mini-starters to the Gen I small blocks. These are for the 153 tooth flywheel starters.
The short one is PN 14037733 and the long one is 12338064. They have 10mm shanks with 3/8" threads.
__________________
“Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.” Colin Chapman
  #23
Old 06-16-2012, 03:11 AM
68/70Vette 68/70Vette is offline
United States | Addict
My Photos: (0)
Default
GM Performance Parts catalog has a ministarter for Small Blocks' and will also work with lower compression Big Block's. They also sell one for high compression Big Blocks. I've bought one of each. They are not all that expensive.
  #24
Old 08-27-2015, 03:56 AM
Kid Vette's Avatar
My Photos: (314)
Default
Well it bit the dust.
Lesson learned. Luckily it crapped out in the driveway, I got to the parts store a couple minutes before they closed and they had one in stock.
  #25
Old 08-27-2015, 10:56 AM
phantomjock's Avatar
phantomjock phantomjock is offline
My Photos: (699)
Default
Kid Vette
What was your replacement of choice? Another mini - or a "standard" off-the-shelf? Would be nice to follow the replacement.
__________________
Rebuilder's Zen Saying:
One thought leads to another. If these thoughts link into a chain we become bound to the project. This bondage is subtle and remains until we complete the tasks -- or, STOP Thinking!
  #26
Old 08-27-2015, 01:40 PM
SRountree's Avatar
SRountree SRountree is offline
My Photos: (104)
Default
will this work? I was told I needed a better started and I found this for $80.00 thru Rock Auto... I have a 383 stroker motor. My speed shop guy said a 96 or so vortex starter was small and it would work too... its $160.00
OR BETTER YET...???
What do you guys think?
__________________
Steve Rountree
513.505.4494
Middletown OH
If you can change your thoughts,...
You can change your world...
  #27
Old 08-27-2015, 07:38 PM
Kid Vette's Avatar
My Photos: (314)
Default
I got a NAPA gear reduction replacement since they had it in stock and I wanted to get the Vette in the garage that night. Lot's of property crime and stolen vehicles in this town thanks to all the tweekers in this town so I didn't want to leave it out.
Not sure I'm going to stick with it though. I want to make sure this doesn't happen again. I was lucky this happened at home.
I wouldn't take a chance on that Amazon starter. Read the reviews. It has to be Chinese junk at that price. I'm definitely going with name brand on my next starter.
  #28
Old 08-27-2015, 11:24 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
MY only comment is, that my vette is rigged so that it's NOT being stolen....unless by a hook.....sure as hell not driving it......
electronic trickery......this one being FI makes it simple....
back in the day, I had a series of latch relays on the '70 Lemans GTO convertible, .....
Interior lights ON, Ignition ON, then button ONE, then button TWO, in sequence, both button hidden......
eff em forever......they may HOOK it but never drive it......
__________________
  #29
Old 08-28-2015, 03:20 AM
Kid Vette's Avatar
My Photos: (314)
Default
That won't stop them from stealing the wheels, etc. The meth heads in this town will take anything that isn't bolted down and they can get a few bucks out of.
  #30
Old 09-01-2015, 03:35 PM
rtj's Avatar
rtj rtj is offline
My Photos: (65)
Default
OR BETTER YET...???
[Only registered and activated users can see links. Click Here To Register...]...
The ac delco starter looks like the one that is on the GMPP BB crate engines. Mine has been very reliable.
I see that is a reman unit now, so maybe a bit more risk than new.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
