Go Back   VetteMOD.com > VetteMOD Technical Discussion > Electrical & Ignition
Reply
Thread Tools
  #1
Old 08-06-2013, 05:43 PM
enkeivette's Avatar
enkeivette enkeivette is offline
Addict
My Photos: (0)
Default C3 window switch failing?
What is the usual cause of these window switches failing? The switch itself or the harness?
  #2
Old 08-06-2013, 06:42 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Over the decades I have seen the plugs corrode and get hot/burn up on the switch terminals, taking the switch with it.....now I also have seen the switches themselves fail.....but if you are careful, you can take the switches apart and clean/polish the contacts, and be fine.....do same with the pegs obviously....and work around/scrub the plug on the switch.....
NOW, years ago, there was a olde tyme TV tuner cleaner, for the contacts on the old mechanical tuners, it was called BLUE STUFF, I still have a can from 35 years ago or so, and use it sparingly.....it's a true miracle worker as my '72 vette and my 70 goat never had any window switch problems after being reworked with that shit.....
been a while.....
__________________
  #3
Old 08-07-2013, 04:31 AM
BangkokDean's Avatar
BangkokDean BangkokDean is offline
Thailand | Addict
My Photos: (14)
Default
I use Sonex spray, it cleans the contacts.
__________________
From the land of smiles
Bangkok Dean
  #4
Old 08-08-2013, 08:32 AM
enkeivette's Avatar
Addict
My Photos: (0)
Default
It was grounding out on the driveshaft tunnel. Surprised this hasnt happened to anyone else. Just glued some polyester under it.
  #5
Old 08-08-2013, 08:34 AM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
If you want to improve the electrics, use relays 2 on each door. The loss through those switches is quite a bit. Windows fly up and down when using relays and a large 12V feed to them.
__________________
  #6
Old 08-08-2013, 06:05 PM
mrvette's Avatar
My Photos: (3)
Default
Quote:
HUMMMM>>>>>
  #7
Old 07-02-2015, 11:18 PM
Raybe's Avatar
Raybe Raybe is offline
United States | n00b
My Photos: (0)
Default switch
Got one if you need it........Ray
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
