rtj
- Joined
- Nov 5, 2011
- Messages
- 2,976
[ame]https://www.youtube.com/watch?v=5PoDNZFK-5M[/ame]
Is it a general rule that removing as much air out from underneath is best?
Even when that air can be used to generate downforce from the diffuser?
These cars also have the opposite of a typical rocker panel "skirt". They are very rounded vs. flat, like the C7Z skirts and most other track oriented super cars
Hope this makes sense - can't say its CFD - just one guy's opinion/idea of what might be going on.
BTW - I did run the SR with side skirts (not authorized - but if you ain't cheatin"...) and the car was very well balanced and like riding on rails. Removed them and have ran with splitters and a wing. Now have 2 tunnels cut into the side pods and they work well. Now in the rebuild am adding a spoiler in lieu of wing. We'll see how that all goes. Still considering strakes similar to the M720.
Again, this makes much more sense :thumbs:That large vertical looking "wing" behind the front wheels is probably responsible for the side skirt area (rocker area) being so different from the c6 or c7.
Jim is right, vortex dominated flow down the sides.
Well it speaks volumes about how much trust your customers have in your work. Big $$$$ there.
Don't know anything about the aerodynamics but I like that car!
This guy claims to be a rocket scientist, but I suspect he may be an actor. Granted he does claim to be an aerodynamicist...
BTW - both are excellent videos- THX rtj!
Continuing with the underbody areo on the M720.
I sourced the following image showing the vanes and splitter on a 520 - similar underbody thinking.
Note the mini-diffuser built into the splitter in front of the tires. These can be very powerful. One outfit did some downforce testing trackside and found these splitters gave a 200% increase in downforce of the splitter. Nice.
Also note that the "tire diffuser" is located below the duct work -- heaps of downforce I'd bet.
Also note these vanes are made as a single piece and mounted. Similar on the 720? Makes the install easier - one set of fasteners and sets the relationship of one vane to the other. Based on testing-or just smart intuition?
There are several great ideas here that can apply to the C3s and keep it "subtle" at the same time.
I'm going for another coffee.
