  #141
Old 11-08-2017, 09:30 PM
SuperBuickGuy's Avatar
SuperBuickGuy SuperBuickGuy is online now
My Photos: (0)
maybe I answered my own question
  #142
Old 11-10-2017, 04:44 AM
My Photos: (0)
as with most, cheap headers, these sort of fit
some trimming required
yum, tasty fiberglass
oddly, it's not at the same level (horizontal)
more hacking
and this side (passenger) looks to need nothing
first step, put spacers in the motor mount
better but where those lines are need heat
now it fits
however, all is not peachy
I had this same issue on Plastic 1
driveshaft mostly installed (need 2 more clamps)
someone asked me once how far the side pipes hang down.... not at all
and Photobucket - I'm moving host, but that means that some of my old threads are going to be de-pictured... sorry, but at this point it's kind of the only choice (and I'm not backing off fighting them)
more bits waiting
this is cool
  #143
Old 11-10-2017, 03:45 PM
rtj's Avatar
rtj rtj is offline
My Photos: (58)
I think hookers fit better than those. I did buy a special spark plug socket with integral u-joint and cut it down some, but otherwise no issues.
Looks good, great progress.
Thanks for the clone greenwood chassis link. Rpmdyno.com, anyone seen more of his build?
  #144
Old 11-11-2017, 01:57 AM
My Photos: (0)
I had hookers on my prior C3 but it was a SBC. This wasn't terrible, it just took fiddling. That said, I think I'll really appreciate the stainless steel tubes rather then the steel of the Hookers.
  #145
Old 11-12-2017, 10:15 PM
bobs77vet's Avatar
My Photos: (2)
what hosting are you going to? I may follow.
that engine install really looks great. it certainly does take up all the space there is to offer....
  #146
Old 11-13-2017, 01:05 AM
My Photos: (0)
the Corvette engine compartment is spacious considering I used to my make my spending money building V8 S-10 trucks and Blazers.... there, 1/4" would make or break a fitment
  #147
Old 11-13-2017, 06:00 AM
My Photos: (0)
Starter, wired
distributor with adjustable collar, arrived
Spark plugs, gapped and installed. In case your curious what lights off the beast - Briggs and Stratton spark plugs.
Dog installed
linkage, installed - one of those times I'm really glad to have a shop full of parts, my goodness that was a pain finding all the bits that worked together
I think the oil cooler is going in front (just not that oil cooler)
Spiderman had red webbing today
still need to do a fuel system but at this point the drivetrain is together (brakes, clutch, driveshaft, etc)
  #148
Old 11-15-2017, 08:21 AM
My Photos: (0)
Time to build a carb
all cleaned and on the new base
I modified the base for boost-reference, so I had to 'fix' that
I know the PO reads this, so normally I don't point stuff like this out - but really, stop it.
should look like this
my favorite, bare wire to nowhere.. think it's a horn wire..
tempted to one-wire this
'the right hose' yeah, no... oh well, I was looking forward to building another upper hose out of stainless
this is probably too close to rice, but I like these gauges because they're easy to read
  #149
Old 11-17-2017, 06:03 AM
My Photos: (0)
Carb assembly
and a problem - the base uses a lever that turns on the body of the carb... which isn't on the proform body
so now I wait for another base...
but it still works for what I need right now - wire routing and fuel system building
the pump
first step is to pull the tank apart so I can install - 8 feed lines and cap the other lines that I won't be using.
pump will go here...
oil sender installed
and wiring commences
  #150
Old 11-20-2017, 03:14 AM
My Photos: (0)
Progress - I cut up several trees that fell in the last windstorm and got prepared for the one that's coming tonight... that said, I did get a bit done
a quick how to make wires
bend tabs more
crimp
halfway there
all the way there
