Limited Viewing Notification! It looks like you're enjoying VetteMOD.com but haven't created an account yet. Why not take a minute to register for your own free account now? As a member you get free access to all of our forums and posts plus the ability to post your own messages, communicate directly with other members and much more. Register now! Already a member? Login at the top of this page to stop seeing this message. |
Thread Tools |
#11
Quote:
or is my knowledge/perspective rong?? it looks as if a two ear version of maybe 1/4" steel with a hole in the middle for the HB to mount...would enable that HB to clear the lower bulge...? then for vibration to use a brace under the units to the lower firewall?? ![]()
GENE When the .gov fears the people, there is LIBERTY, when the people fear the .gov there is tyranny ... "Sure, there are some bad Republicans, but there are no good Democrats." Liberalism - Childlike emotionalism applied to adult issues I have a little list, let ALL of them be MIST...... [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] |
#12
I was thinking a hunk of alum like this would be the way to go. Hole saw the center out and drill your four mounting holes. Then you can trim it, shape it and polish it for looks.
#13
I'm just speculating, but my HB unit came with two different length pushrods. Naturally, the one installed was not the one that I needed. It wasn't too hard to get the installed one off, but there isn't much to hold on to to gently hammer the new one on (see the reference above to splitting the female part). I took a cheap, Chinese wrench and ground it to fit the female part so that I could grip it enough to hammer in the rod. I suspect that the Kent-Moore tool does the same thing. I can also see how you could easily split the part.
| Thread Tools | |
