Go Back   VetteMOD.com > VetteMOD Technical Discussion > Wheels, Tires and Brakes
Reply
Thread Tools
  #1
Old 10-17-2012, 10:12 AM
enkeivette's Avatar
enkeivette enkeivette is offline
Addict
My Photos: (0)
Default C6 calipers an advantage over C3 calipers?
So, after searching google for an hour and finding nothing I figured it was time for some expert advice...
I scored a set of C6 Z51 brakes tonight thanks to BadAssC6. And I noticed that the fronts are only 2 piston, and the rears are only 1 piston calipers. So... would there be any advantage?
Im going to at least run the 13.5 rotors... but Im debating whether I should do it with my stock calipers or not.
Do I need to run a c6 booster/ master to appreciate the advantage?
IM NOT WORRIED ABOUT FITMENT, STAY FOCUSED. HAHA
  #2
Old 10-17-2012, 11:21 AM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
C6 Z51 is the same as all non Z51 and C5 stuff with the exception of a larger Rotor. C5 uses a 13ish ich rotor, the Z51 uses I think in the vicinity of 13.5 The oly diff. are the abutments. That said, if someone has the C5 caliper adapter brackets dimensions you can simply use those. In fact, even C6Z06 calipers will bolt to that. I did that on 1 of my 3rd gens. Had C5 calipers w/ bare rotors on it, swapped those to another 3rd and installed Z06 stuff on it, now off again because I want 15" rotors
The discs are all 1.25 wide. These are floating calipers, the pistons extend twice as far as the whole caliper moves over, so in effect they are virtual 4 piston fixed calipers. On floaters, always double # of pistons comparing to fixed calipers because the pistons extend twice as far.
I would upgrade to C5 master, easy lightweight and a lot better looking that a arusty stock C3 MC.
__________________
  #3
Old 10-17-2012, 04:45 PM
enkeivette's Avatar
Addict
My Photos: (0)
Default
What about running c3 calipers on the c6 rotors?
And is there any benefit to going with a c6 booster? Are the c5 master and booster the same as in a c6?
  #4
Old 10-17-2012, 08:13 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
Why would you want to use an inferior calipers?
No need to swap boosters, would be quite problematic if you ask me, probably different bolt pattern, push rod length is not the same...etc...etc...
  #5
Old 10-18-2012, 07:55 AM
enkeivette's Avatar
Addict
My Photos: (0)
Default
And a c5 master will bolt right to the stock booster? And other than looks, is there any reason to go with a c5 master?
Thanks again btw TT!
  #6
Old 10-18-2012, 02:00 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
bolt on, lighter weight, wont corrode, won't leak, can hook up level switch for a warning lamp. You only need to do custom lines. Get adapters, have customs lines made, make yourself... do a search. BBShark and 69427 have topics on it. I used custom made stainless braided lines w/ 2 different ends (metric and imperial)
  #7
Old 10-18-2012, 09:21 PM
enkeivette's Avatar
Addict
My Photos: (0)
Default
But it doesnt improve braking??
So technically a c3 master/booster will provide the same braking with c6 brakes, as a c6 master/booster??
I thought I remembered reading about someone on CF who installed c5 brakes and he said the braking wasnt any better, and suspected it was because of the old master/booster.
One thing I think I really do need is a vacuum pump. I need to leave it in gear when Im braking or theres not enough vacuum to stop! Haha
  #8
Old 10-18-2012, 11:29 PM
010752 010752 is offline
Addict
My Photos: (0)
Default
Dammit man, just Dammit... Hydraboost.
  #9
Old 10-18-2012, 11:50 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
The C5 master has a smaller bore so slightly lighter pedal but more travel.
If one installed 13" C5 rotors and the calipers and braking hasn't improved something is really wrong. Forget the line pressure differences you may see or piston size differences, the brake torque increase alone should make a big difference.
I have C5 calipers on my 88 camaro and it stops on a dime. It's better than the C4 HD 13" system.
  #10
Old 10-19-2012, 01:03 AM
SmokinBBC's Avatar
SmokinBBC SmokinBBC is offline
United States | Addict
My Photos: (4)
Default
Quote:
Classic
__________________
Have you updated your garage lately?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
