Go Back   VetteMOD.com > VetteMOD Technical Discussion > Classic Corvettes
Reply
Thread Tools
  #1
Old 07-28-2017, 11:49 PM
Kev'C3's Avatar
Kev'C3 Kev'C3 is offline
United States | n00b
My Photos: (2)
Default Ball joint choices.
Hi,I all are well and having fun working or driving their Vettes. Has one used QA1 ball joints 1210-103 as oppose Howe ball joints 22301? And what is your preference? Looking for ball joints to use with SPC control arms 92740. Your help would be much appreciated. Thanks!
  #2
Old 07-29-2017, 10:36 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (251)
Default
The QA1 joints look like nice parts. Extending the stud sort of seems like it might be a problem but you would see complaints if it were. The Howe stuff has a good reputation but not sure they make the rebuildable type
__________________
  #3
Old 07-29-2017, 11:24 AM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (33)
Default
My car has spc upper arms and tall Howe ball joints. Works great, best/easiest alignment after change.
Do a search, the tall Howe ball joints improve steering geom. on c3's with oem spindles.
  #4
Old 07-29-2017, 07:15 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Heard of them over 'there'....and AS I RECALL, the bolt pattern means the upper arm needs drilled, but the longer stem raises the arm....but I totally lost as to what that does to help the handling....I MAY go furr a set of them when time comes.....are they USA made?? or China??
__________________
  #5
Old 07-29-2017, 08:14 PM
rtj's Avatar
rtj rtj is offline
My Photos: (33)
Default
Speedway motors has them, or buy direct from Howe racing. I think 1" over is the most you can get. Bolt in units for C3 available.
  #6
Old 07-30-2017, 02:07 PM
rtj's Avatar
rtj rtj is offline
My Photos: (33)
Default
One thing, spc a-arms need a travel limiter.
  #7
Old 11-18-2017, 02:14 AM
CiroRacing CiroRacing is offline
My Photos: (0)
Default
Does your wheel contact the SPC upper arms? My friend had that issue on his Camaro. I talked to the originator of the SPC arms, and I purchased the top plate that takes the Howe nascar/mopar style taller upper ball joint. The nascar ball joint threads into a narrower top plate, instead of using the wider ball joint that has a 3 or 4 bolt flange.
Rick
  #8
Old 11-18-2017, 06:07 AM
rtj's Avatar
rtj rtj is offline
My Photos: (33)
Default
Rick
No wheel contact, but I have 3" bs.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
