Carburated Nihilist
In an attempt to troubleshoot my non functioning tach, I'd like to make a tach signal generator.
I'll use a microcontrolleur or a 555-based circuit, depending of complexity of the signal to generate.
Do you guys knows the specs of the signal?
Voltage: 12v,13.8v, other?
Signal shape: square or pulse?
Hz to RPM ration?
Any amp requirement for the signal line?
If anyone has answer to any of those questions, i'm listening.
Thanks.
Hz to RPM ration?
Thanks.
