Go Back   VetteMOD.com > VetteMOD Technical Discussion > Engine
Reply
Thread Tools
  #1
Old 09-27-2014, 08:08 PM
496BBC's Avatar
496BBC 496BBC is offline
United States | Addict
My Photos: (61)
Default Issues with Holley Big Port Regulators
Anyone else having issues with Holley regulators?
I've had two doing the same thing,
they chatter and will not maintain pressure, they chatter so bad it will shake the needle off the gauge.
I replaced the Holley with an Areomotive 13201 and it is solid as a rock.
I was using the Holley big port regulators,
Neal
  #2
Old 09-27-2014, 10:09 PM
Stroker-427 Stroker-427 is offline
Italy | Addict
My Photos: (39)
Default
Same thing !!!
Bad regulators..... tens of broken pumps..... many problems....
But everything went fine when I bought Aeromotive 13201 regulator an Aeromotive A1000 fuel pump.
Very good stuff, to me !!!!!
  #3
Old 09-27-2014, 10:51 PM
496BBC's Avatar
My Photos: (61)
Default
Yep, going to start switching over to all Aeromotive stuff shortly,
running the Holley Black pump right now and have had good luck so far,
Looking to go all Aeromotive SS Series stuff,
Neal
  #4
Old 09-27-2014, 10:53 PM
496BBC's Avatar
My Photos: (61)
Default
Quote:
Originally Posted by Stroker-427 View Post
Same thing !!!
Stroker how is the 13201 working with the A1000 pump?
their web site suggest a different regulator for the A1000 but since I already have the 13201 it would be great if it would work.
Neal
  #5
Old 09-28-2014, 05:17 PM
Italy | Addict
My Photos: (39)
Default
To be honest I can't remember the part number..... but is an Aeromotive bypass regulator..... which is very important if you have a very big pump like the A1000.
I have a huge collection of broken fuel pumps..... and erratic regulators.
Aeromotive was the cure !!!!
  #6
Old 09-29-2014, 01:23 AM
496BBC's Avatar
My Photos: (61)
Default
thanks for the reply,
well my issues are not resolved, started having issues with the Aeromotive regulator today, pressure just falls off to 2 psi while accelerating and once I let off to level out the pressure returns.
I'm going to install a gauge in the supply line just before the regulator and see if the pump is the problem.
it never stops with this hobby,
Neal
  #7
Old 09-29-2014, 06:31 AM
Italy | Addict
My Photos: (39)
Default
Have you connected the vacuum tube from the manifold to the eventual connecton in the regulator?
If yes, this can be the problem.
If not the problem should be the pump.
Can you post a pic of the istallation ??
  #8
Old 10-01-2014, 01:55 AM
496BBC's Avatar
My Photos: (61)
Default
I don't have any pics right now,
The pump is mounted in the rear of the car near the tank pulling suction from the OE unit and discharging into the OE fuel line to the engine compartment where the regulator is mounted to the passenger fender near the overflow tank. From the regulator to the carb fuel log is a 8AN line with a 10 micron filter. The second outlet of the regulator is connected to the return line with a .060" bleed jet.
I sent this description to Aeromotive and they suggested that the pump may be cavetating due to the suction line.
Neal
  #9
Old 10-01-2014, 08:32 PM
Italy | Addict
My Photos: (39)
Default
Yes, it can be a cavitation issue....
...or some air sucking in the line from the pump to the tank !
  #10
Old 10-05-2014, 04:33 PM
496BBC's Avatar
My Photos: (61)
Default
Tried removing the bleed jet and playing with the adjustment of the Aero regulator today.
The regulator does not react to the adjustments right away its like the regulator is sticking.
I took a ride after working the regulator back and forth and things are a little better. The fuel pressure is a lot more stable now at 6 psi and is holding there even when driving.
Now I think I need to look at the pump, when I get in it for a few seconds the pressure drops to around 1 psi, when I get out of it the pressure comes back.
I'm going to install the Holley regulator and see if it has the same symptoms, if so I know I need to look at the pump.
I've made quite a few runs at WOT in the past but have not watched the fuel pressure. I do have a wide band with data logging and have never seen the AFR go lean at WOT so don't think it was a issue in the past but it is now. The pump may be going out and its time to change it.
Neal
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
