Go Back   VetteMOD.com > VetteMOD Technical Discussion > Engine
Reply
Thread Tools
  #11
Old 01-03-2010, 02:49 AM
496BBC's Avatar
496BBC 496BBC is offline
United States | Addict
My Photos: (61)
Default
The heater cores were added when I added the oil cooler, a few months ago.
Neal
  #12
Old 01-03-2010, 10:06 AM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
You added cores to the bypass hose? It's not a bypass hose in that it bypasses the thermostat, it's an anti cavitation line. With a restriction in it, the pump will cavitate and this severely affects pumping volume, even completely stalling flow. No wonder you had those funky readings.
__________________
  #13
Old 01-03-2010, 02:11 PM
496BBC's Avatar
My Photos: (61)
Default
Yes I added heater cores to the bypass line to add some cooling.
It was recommended to remove the bypass line all together when I tried to remove it the temps would swing. The thinking here was a lot of hot water was bypassing the radiator and could be adding to the heating issues I was having so removing the bypass line would force all the water form the engine to pass through the radiator. Well along the same lines I added two heater cores to the bypass line to allow some water flow but to also add some cooling along with it. This seems to have caused enough disruption in flow to cause the pump to cavitate.
After I put the bypass line back like it should be the temps form each head are within a couple degrees of each other.
Neal
  #14
Old 01-03-2010, 10:00 PM
damoroso's Avatar
damoroso damoroso is offline
My Photos: (0)
Default
Sounds like it's all sorted out now! The next trick is to see how it works in August with the A/C on and in traffic. That's what I'm waiting for, if it stays cool then, all is right with the world!!
  #15
Old 01-03-2010, 11:35 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Quote:
I dunno Dave, the way this hemisphere is cooling now, it maybe AUGUST before you can pull that test....
__________________
  #16
Old 01-04-2010, 01:52 PM
damoroso's Avatar
My Photos: (0)
Default
No kidding, the fountains here at the house have been frozen the past two mornings!!! Next thing you know we'll be shoveling driveways. That damn George Bush and his global warming!!!!
  #17
Old 01-04-2010, 02:27 PM
mrvette's Avatar
My Photos: (3)
Default
HUmm...so there is, on the front pot, pump running but a skin of ice....
shit....
  #18
Old 01-05-2010, 02:06 AM
496BBC's Avatar
My Photos: (61)
Default
Yep the true test will be July and August
got my fingers crossed
Neal
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
