Go Back   VetteMOD.com > VetteMOD Technical Discussion > Electrical & Ignition
Reply
Thread Tools
  #1
Old 03-28-2008, 02:48 AM
big2bird's Avatar
big2bird big2bird is offline
United States | Charter Member
Founder Bird-Run
Cruise-In Bird-Run 1 Veteran
Cruise-In Bird-Run 2 Veteran
My Photos: (342)
Default Mini starter and the points ignition. Simple solution
If you read muy post on Scotts headlight modification, you know I added a 3rd relay. This is for the ignition.
On the old tach drive points systems, a resistor wire feeds the coil, limiting the current to 4 amps. Upon start up, a contact on the starter shunts this to provide a full 12 volts at start up. It also provides an easier hot restart.
WHEN you install a mini starter on a points ignition car, you LOSE this function. Here is the cure.
1) Run yourself a new keyed hot from the spare tab in the fuse box to a relay under the hood. Jump from this same point to one side of an external ballast resistor. Since most 8 cylinder coils are 1.5 ohms, use a bllast resistor of 1.5 ohms. This leaves you with a total of 3 ohms, giving the desired 4 amps at 12volts.
2)From the other side of this "shunt"relay, run a #16 wire to the other ballast resistor terminal, and from that same terminal to the + side of the coil. The - post is always the point side.
3)To activate the relay, run a #16 black to a known good ground, and the other side of the coil to the starter. Splice in to the purple coil wire there.
Now, when you turn on the key, the coil is fed via the ballast resistor.
When you are CRANKING the car, the relay pulls in, insuring full voltage to the coil for easier starting.
I will ask TT to autocad a drawing to post from my sketch.
Shunt relay is on the left.
Ballast resistor.
__________________
I can make your dizzy. Really, I can.
  #2
Old 03-28-2008, 04:19 PM
BRUTAL64's Avatar
BRUTAL64 BRUTAL64 is offline
United States Outlying Islands | Neanderthal
My Photos: (4)
Default
Ballast resistor.
Good job! Does away with the FORD hot start fix.
__________________
"If it is left to the present Congress, weíll get the best thinking of the eco-nazis, the safety nazis, the California Air Resources Board, Speaker of the House Nancy Pelosi, and the Biosphere 2 people. For the good of the nation and its citizens, these clowns should be kept as far from our automobiles as is politically possible."
David E. Davis Jr.
64 Vette Roadster 400 ci- Dual Quads
70 Thunderbird 429 ci
48 Harley Panhead 76 ci
  #3
Old 04-02-2008, 03:11 AM
Theiskell's Avatar
Theiskell Theiskell is offline
The Hillbilly
My Photos: (0)
Default
Big bird,
When you say install a ballast resistor is that for cars that donít already have one. I am in the process of this at the moment and from what I understand on my í69 is that the wire from the firewall already has the resistor 9.5 volt (I think) and the wire from the starter is a normal wire. So would I need the resistor in my case?
  #4
Old 04-02-2008, 03:15 PM
big2bird's Avatar
Founder Bird-Run
My Photos: (342)
Default
Quote:
Originally Posted by Theiskell View Post
Big bird,
No. I did that to simplify what Scott had installed.
You could take a keyed hot from your fuse box, and use it to feed the relay contacts. Your "switched end " would feed the coil + terminal directly.
  #5
Old 04-02-2008, 04:50 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
If you run any kind of ignition box you will not need a ballast resisstor.
__________________
  #6
Old 04-02-2008, 05:25 PM
Theiskell's Avatar
The Hillbilly
My Photos: (0)
Default
That sounds good. I thought I had it figured out in my head and then I read your post and just wanted to be sure. Here is what I am going to do make sure it sounds right. I will use the purple wire to pull in the coil on the relay and use a 12 volt switched power source to feed the coil from the switched side of the relay.
  #7
Old 04-02-2008, 05:31 PM
Theiskell's Avatar
The Hillbilly
My Photos: (0)
Default
Quote:
Is the resistor wire only to keep from burning up the points? I am also thinking about getting a conversion from points to electronic ignition. Iím just not sure the money will hold out on the build this thing is killing me. Also if I do go over to electronic will I need a new coil?
  #8
Old 04-03-2008, 05:06 PM
big2bird's Avatar
Founder Bird-Run
My Photos: (342)
Default
There you go.
  #9
Old 04-03-2008, 05:09 PM
big2bird's Avatar
Founder Bird-Run
My Photos: (342)
Default
Yes. It limits the current to 4 amps. Most all V-8 coils are 1.5 ohms, so you use a 1.5 ohm resistor to get a total of 3 ohms. 12v/3 ohms = 4 amperes
The points unit properly curved will work fine up to 6,000 RPM.(crankshaft speed)
  #10
Old 04-03-2008, 10:31 PM
Theiskell's Avatar
The Hillbilly
My Photos: (0)
Default
Thanks for the help on this guys
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
