Go Back   VetteMOD.com > VetteMOD Technical Discussion > Other Cars
Reply
Thread Tools
  #11
Old 12-31-2008, 04:08 AM
Fuelie74's Avatar
Fuelie74 Fuelie74 is offline
United States | Addict
My Photos: (15)
Default
What trans do you have?
  #12
Old 12-31-2008, 04:26 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (266)
Default
Quote:
Originally Posted by 1982VetteGuy View Post
Quote:
Originally Posted by BBShark View Post
My Tahoe seems to "hunt" for a gear at certain speeds. About 40 and 60 mph with steady throttle and level ground. It's weird, like maybe the converter is trying to lock causing the truck to very slightly buck intermittently unless you speed up or slow down. 3 mph up or down and it goes away.
Any ideas?
If it's a 4L60e transmission, it's a factory defect problem. Something to do with the bores in the valve body wearing out and not holding pressure.
You can buy a "fix it kit" on ebay for around $40 and requires pulling the valve body and tearing it down to re-drill the bores with oversize seals.
My 2000 S-10 done the exact thing your describing, I bought a used valve body off ebay from a transmission vendor that guarantees these to work. He cleans and checks them. It cost me less than $100 and 8 hours of my time to replace.....my car shifts and runs like it did the day I bought it.
Dealers charge upwards of $350 - 400 to do this repair..
Do a search for "code 1870" on google and you'll see what I'm talking about. Sometimes it will throw a check engine light...sometimes it won't.
I'll have to check into that, thanks.
__________________
  #13
Old 12-31-2008, 04:28 AM
BBShark's Avatar
My Photos: (266)
Default
Quote:
I beleve I have the 4L60E. It is a 97 Tahow with 4wd and a 5.7l.
  #14
Old 12-31-2008, 06:41 PM
1982VetteGuy 1982VetteGuy is offline
United States | n00b
My Photos: (0)
Default
I bet that's your problem, my truck would get up to highway speeds and felt like the converter was going in and out of lock-out....it even jerked.
This wasn't limited to trucks, I noticed some cavalier and camaro owners having the same problem.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
