  #1
Old 08-26-2020, 02:58 PM
CollegeKevin's Avatar
CollegeKevin CollegeKevin is offline
United States | n00b
My Photos: (1)
Default SPC UCA Race or Street
Looking to buy a set of SPC upper control arms to make it a little easier for me to do the alignment myself. I plan on trying autocross but will also be street driven (local cars and coffee meets).
My question is, should I go with the Race version (delrin bushings) thats like $40 cheaper, or the street version (rubber bushings)?
From the pictures it appears the street version will accept a stock ball joint, whereas the race looks like a 4 bolt design for the BJ.
Any info/reviews would help me out deciding.
FYI, I spoke with SPC and apparently they will be releasing a new billet version under part number 97160 in a month or so but will be priced around $1,000 for the set (including ball joint).
  #2
Old 08-26-2020, 03:20 PM
phantomjock's Avatar
My Photos: (684)
You say you spoke with SPC. Was that the company or Mark (Savitske)?
If the company, I suggest you give Mark a call. Make sure you have some time to talk - it might not be a quick answer. He is very knowledgeable. He can also give you some alignment hints too.
His page is: [Only registered and activated users can see links. Click Here To Register...]
Phone not listed on site (610-346-8154).
Get a copy of his book - How to Make Your Muscle Car Handle.
I'd go bone jarring Delrin personally. The set I got from Mark are 3/4" shafts with thread in ball joints. Setting up to race (since 2009!)
Rebuilder's Zen Saying:
  #3
Old 08-26-2020, 04:51 PM
rtj's Avatar
rtj rtj is offline
My Photos: (90)
Here is an old thread when I installed some. Didn’t expect a travel limited.
I thought mine were brass bushings, I’ll have to check. Either you mention would be fine.
I installed the tall upper ball joints from howe racing later.
  #4
Old 08-26-2020, 07:59 PM
My Photos: (1)
Quote:
Here is an old thread when I installed some. Didnít expect a travel limited.
I thought mine were brass bushings, Iíll have to check. Either you mention would be fine.
Ive read your post numerous times over the week. Thank you for the info. How long of a limit strap did you need to use?
  #5
Old 08-27-2020, 04:07 PM
rtj's Avatar
rtj rtj is offline
My Photos: (90)
I can check, but it depends on where you mount the two brackets. Just jack the front end up to the point where you want to stop the a arm and lock down the cable. Do one side at a time by jacking one side on the frame. Make sure on full or high compression the slack cable doesnít interfere.
  #6
Old 08-27-2020, 11:27 PM
rtj's Avatar
rtj rtj is offline
My Photos: (90)
Looks around 7Ē in length, by laying a tape on it.
  #7
Old 08-28-2020, 12:32 AM
My Photos: (1)
Thanks very much. You didn't have to do all that. I was just hoping to order some straps before the arms come. Think they'll be here this weekend so I'll pull it all apart and make something work. I like the cable idea as I have that stuff at work. Maybe a free solution.
  #8
Old 09-16-2020, 01:43 AM
My Photos: (1)
Think I'm gonna have to give SPC a call. Wondering if I should use the longer ball joints. Not sure what the advantage is but at full droop the ball joint cup looks a little stressed, not that it will see full droop often.
  #9
Old 09-18-2020, 02:26 PM
rtj's Avatar
rtj rtj is offline
My Photos: (90)
The tall ball joints are sort of a geometry improvement for the old suspension. I think there is a thread on here. Let us know what they say.
  #10
Old 09-19-2020, 09:34 AM
My Photos: (684)
I sent Mark a question via email and he got back to me the next day
Quote:
Hi Jim,
They`re not GM components, they`re Howe Racing. They`re available in .10" increments. What height would you like? FWIW we spent a lot of time testing these and the +.50" you already have worked out best on all of our test cars.
Not the bolt-in type you have but the screw in (rebuildable).
Great service from him.
Cheers - JIm
