  #781
Old 01-21-2020, 06:09 PM
bobs77vet's Avatar
My Photos: (13)
Quote:
Originally Posted by SuperBuickGuy View Post
Quote:
Originally Posted by mfain View Post
I'm really glad you fixed the fender flare to center the wheel. That was going to bother me forever. Nice work.
Pappy
the hardest part of the job was getting over that I paid $2000 for that crap....
yeah those are the moments we can quickly push behind us
  #782
Old Yesterday, 05:35 AM
SuperBuickGuy's Avatar
SuperBuickGuy SuperBuickGuy is online now
My Photos: (0)
I still don't have a solution for the sway bar - it is too close to the coil over (stock had a transverse spring)....edited
but I started reassembly of the under so that I can get the bracing done
  #783
Old Yesterday, 05:41 AM
My Photos: (0)
so I spent some time on the motor.... glad I did because I need to call the rocker manufacturer and find out what they were thinking
first front cover install (and oil pan)
and water pump
lifter install
then onto figuring out push rod length
the issue with the rockers - there's a cast piece that holds the stock rockers in place - that has a radius to match the rocker. The new rockers come tied together and have spacers - ostensibly to replace that part - but that puts the rockers way too low.... so I dunno, time to phone and find out what to do.
  #784
Old Today, 04:47 AM
My Photos: (0)
and maybe the most important thing.... I have a Microsquirt that I was going to use on the FJ40.... zero new dollars and zero new cents is very attractive
​​​​​​​feel free to discuss here
- and as he mentioned in the video - the transmission could be the issue. I can buy a GM pre-wired harness from 150tunes for $550 - and that is already wired to run the 4L80e.... that said, this motor is temporary to the car (whatever that means) and my goal is a no-limits 3800 V6 - which leads to transmission concerns..... and I have the 200r4....
