JeffP1167
I am curious if this whatever it is was used to seal a crack in my differential or it was put here maybe by a rebuilder so they could tell if anything was tampered with for warranty reasons.
You can also see it in the area where the C-beam bolts pass through.
Either way it has to be welded if it is a crack since I am polishing all of this, but is a weld here risky or should I just replace the housing if it is cracked?
