Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #1
Old 12-29-2009, 06:39 PM
1Michel 1Michel is offline
Canada | Addict
My Photos: (494)
Default Control arms
Are the control arms different thru the years,
are the control arms from a 72 frame interchangable with a 76 frame??
__________________
Eat dessert first! life's unexpected!
  #2
Old 12-29-2009, 07:00 PM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
I don't think there's a difference, should be all the same from 68-82. I think even the 63-67 are the same control arms.
__________________
Link to my garage:
  #3
Old 12-29-2009, 07:15 PM
Canada | Addict
My Photos: (494)
Default
Thats what I thought,
I dropped the body on the new frame and the upper control arm up and down movement is rubbing on the fiberglass inner fender.
It's not in the middle like the old ones.
Measured the frame all over and everything seems straight and true.
The body is aligned with the alignmnt holes.
I'll get some pics a little later.
  #4
Old 12-29-2009, 07:42 PM
MYBAD79's Avatar
My Photos: (882)
Default
hmmm.... did you swap left/right ???
  #5
Old 12-29-2009, 08:35 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Quote:
BINGO!!!
__________________
  #6
Old 12-29-2009, 09:32 PM
phantomjock's Avatar
phantomjock phantomjock is offline
United States | Addict
My Photos: (688)
Default
hmmmm... I say hmmmm.
Aren't they fairly symetrical? -- (The uppers.) Just looked at mine and look pretty much the same. Didn't measure - but they're off and will do that if needed. Replace mine with the SPCs- and the lowers with the VB&P monoleaf setup)
The lowers would be hard to goof up with the dual bolt mounts forward and single aft - and the fitments for the sway bar is forward.
Did you change out the ball joints? Remove the spindles? Get them back on correctly?
If you'd like a measure of the Upper A Arms - let me know and ll shoot a pic and add to this thread.
Interesting -- and confusing...
CHeers - Jim
__________________
Rebuilder's Zen Saying:
One thought leads to another. If these thoughts link into a chain we become bound to the project. This bondage is subtle and remains until we complete the tasks -- or, STOP Thinking!
  #7
Old 12-29-2009, 09:37 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
No, they are not symmetrical:
this is a pass side one, the balljoint mount is offset to the rear of the car
__________________
  #8
Old 12-29-2009, 09:42 PM
My Photos: (688)
Default
TT -- Thanks - you saved me from going out into the rain to get them out of the scrap pile! Nice choice using the tiles for accurate measurements!
Per the VB&P catalog -- their uppers and lowers fit all C-3s from 68-82 - so must be a left/right swap?
  #9
Old 12-29-2009, 10:07 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
The tiles were not purposely placed like that LOL
The VBP tubular things are side specific too, I think they mean that the arms fit any chassis, as in a pair of uppers or lowers not 1 arm. Even then, it should read 68-82.
  #10
Old 12-29-2009, 10:12 PM
mrvette's Avatar
My Photos: (3)
Default
Curious as to what if the diff from 63-67, Mid years?? thought the chassis was the same just a body swap....
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
