Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #11
Old 05-18-2008, 03:15 PM
Stroker-427 Stroker-427 is offline
Italy | Addict
My Photos: (39)
Default
I know Marc..... I only would like to save some thing of our C3 steering system!
Of course the most important effect os the steering is the pump (or bump) steer!
In a front steer system is very easy to have some bump-understeer...... and with rubber on the arms.... even load steer in is the right way!
  #12
Old 05-18-2008, 08:43 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
Quote:
Originally Posted by Belgian1979vette View Post
Any ideas on what would be necessary in terms of centerlink ?
Something like what Norval did, you have to plot out the whole system and figure out where the revised tie rod mounting points should go.
__________________
  #13
Old 06-21-2008, 02:59 AM
killervette666 killervette666 is offline
n00b
My Photos: (0)
Default
I got an adjustable outer tie rod setup like that because I have some bumpsteer, I don't have the money or know how to completely redesign the front suspension, so what is the best I can do with what I got, basically, how much should I drop the outer tie rod to get rid of as much bumpsteer as possible?
I read the bumpsteer sticky, but that is way too involved for what I have time or money for (at least right now)
Thanks
__________________
1979 L-48, too many mods to list
  #14
Old 06-21-2008, 03:12 AM
Yellow73SB's Avatar
Yellow73SB Yellow73SB is offline
United States |
My Photos: (11)
Default
3/4 of an inch
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
