Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #21
Old 04-18-2008, 08:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks TheSkunkWorks is offline
United States | Addict
My Photos: (9)
Default
Not wanting to guess by looking at your pics, but what's your rear D height? Looks less than 1", or is your camber strut bracket non-stock? One reason I ask is that I had thought I'd worked out that a 285/40ZR18 should clear on a 10x18" w/5.5" BS, and I'm wondering how much your ride height is contributing to the slight clearance issue you have.
BTW, I don't see anything aesthetically wrong with thinner fender lips as long as you follow thru and make them the same all around.
__________________
If your shark can't pull at least 1 "G" you've got more work to do. [Only registered and activated users can see links. Click Here To Register...]
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
