  #131
Old 07-20-2018, 10:00 PM
vette427sbc's Avatar
My Photos: (26)
I dont think ive ever seen those raised flares before... I had issues with compression travel with my previous suspension and stock fenders... I dont know how you would get any more unless it was a custom frame car. They do look cool though! These tires are going under stock front fenders and 2" flared quarters. (assuming my measurements are correct!)
Chris
AutoWorks Middletown NJ
@autoworksnj
  #132
Old 07-22-2018, 04:43 PM
69427's Avatar
69427 69427 is offline
My Photos: (2)
Hey, man, the frame and suspension mods are looking great.
  #133
Old 07-24-2018, 01:22 AM
My Photos: (26)
Fuel tank showed up this weekend from DMP Fabrication... to say Im impressed is an understatement! The end caps are billet with integrated mounts to distribute the load and the center section sheet aluminum is one piece to minimize stressed welded areas. Its also braced/baffled internally for the Aeromotive Stealth in-tank pump. Weighs 26 lbs with the pump. The bottom side of the tank is angled to follow the contour of the quarter panel to help get rid of the rear "parachute". It came out to about 23 gallons.
Quote:
Thank you! Design is fun, building is fun, driving is fun, hopefully learning to read the car and tune this suspension will follow suit!
  #134
Old 07-25-2018, 10:17 PM
My Photos: (26)
Some small progress with the oil system...
Remote filter mounted, and should be rather accessible through the wheel well
Pan and oil feed plate mounted
  #135
Old 07-25-2018, 11:46 PM
69427's Avatar
My Photos: (2)
Looking good.
I've been trying to figure out if it might make sense to put a similar shaped/full length pan on my engine (I'm still running a wet sump). It would give a bit more clearance from the crank on the front half, and a bit more capacity, but I still haven't resolved all the slosh/trapdoor issue questions yet.
  #136
Old 07-26-2018, 02:44 AM
My Photos: (26)
Looking good.
I would say if you don't need more capacity, then don't add it. It seems like you have your car dialed in pretty well... I'm surprised you don't have (need) an accusump... also, a quart of oil is a fair amount of weight!! Im thinking of running oil cooler-less in hopes that my added capacity and external oil storage away from the hot motor will stay reasonable during 20 minute track sessions. wishful thinking...
  #137
Old 08-10-2018, 01:33 AM
My Photos: (26)
Got my new brackets and some fittings for the oil pump today, so motor went in for mock-up. Its much tighter than I expected! Im going to need to put some serious thought into how this stuff will be routed...
As of now, the scavenge lines from the pan to pump are figured out. They are Earls Prolite 350 -12 with an internal spring. I thought I ordered -10 for the pressure side but apparently I ordered -8 instead... so pressure side will have to wait until next week.
Lines are separated because the Pressure-In line is going in between them
  #138
Old 08-10-2018, 01:52 AM
SRountree's Avatar
SRountree SRountree is offline
My Photos: (94)
WOW, Looking good!
Steve Rountree
513.505.4494
Middletown OH
If you can change your thoughts,...
You can change your world...
  #139
Old 08-10-2018, 12:15 PM
rtj's Avatar
rtj rtj is offline
My Photos: (62)
Great job. Time for me to wrap up home improvements and get back to cars.
I admire the level of detail.
  #140
Old 08-10-2018, 12:18 PM
phantomjock's Avatar
phantomjock phantomjock is online now
My Photos: (699)
This is some really NICE WORK! I have a couple of quick questions:
1. How far aft do you reckon the engine is from stock? 12-13 inches maybe?
2. Who built the drive shaft? I'll need a shorty too as my engine is that far aft as well.
3. What "brand" is the steering unit? Looks like a short track unit? Speedway maybe the source?
On the steering - I like the position it is in too - well forward - I may copy as I'm having some shaft line up problems in the "stock" location. Can't see the front hubs - guess they are "reversed" to get the tie rods up front. Photos when you can - please.
Very sanitary looking chassis - really, really nice.
Rebuilder's Zen Saying:
