Go Back   VetteMOD.com > VetteMOD Technical Discussion > Drive Train
Reply
Thread Tools
  #11
Old 04-08-2015, 01:21 AM
Bullshark's Avatar
Bullshark Bullshark is offline
United States | Addict
My Photos: (184)
Default
Nice Easter basket. So, already have a removable cross-member I assume. Makes the job much easier!!
  #12
Old 07-19-2015, 11:45 PM
JPhil's Avatar
JPhil JPhil is offline
United States | Huh?
My Photos: (140)
Default It lives!
Backed it out of the garage last night about 6:30....WOW! This is what these cars are meant to have! I can't believe I ran an automatic for so long. Feels like a completely different car, for the better. So much more responsive. I hadn't realized how slushy the TH400 was even though I had it hopped up as well. I'm sure the fresh 383 in front of it helps a bit too, but the difference in the way it feels as a "performance car" is magnificent.
Only have about 50 miles on it so far, but I'll be racking up more quickly. I'm still taking it easy for break in, I can hardly wait to really exercise it. I'm really looking forward to putting it on the dyno too, to see what the difference in power to the wheels is compared to the TH400. I sure feels like a lot more, even given that I now have a direct connection thru more gear ratios.
And now I really have to get back into getting the handling dialed in better to help it reach its potential abilities....
Man, this is great!!
__________________
Kill the Buddha
  #13
Old 07-20-2015, 05:22 AM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
Sounds like you like the "upgrade" 👍
I remember when I did it back in 2007, totally feels like a different car !!!!
__________________
Link to my garage:
  #14
Old 07-20-2015, 05:15 PM
84rzv500r's Avatar
84rzv500r 84rzv500r is offline
United States | Knows just enough to be dangerous!
My Photos: (105)
Default
yep... 6 speeds rule... nothin like havin a NEW ZL1 camaro pull up alongside and tease me by rompin on it... downshift down to third and the fun began... imagine his suprize when he found out I have more torque and 1200 lbs less weight to move...
__________________
1971 Can-Am, 502 Ramjet, CC Rollers, hookers, 14 pt cage, Lakewood, McLeod RST DD, ROD 6 trans, 3.08 rear, Wilwood brakes, Hydraboost, Steeroids, Tubular A-arms, QA1 DA and Viking DA shocks, VanSteel HD offset TA's w/Johnny Joints, 6 link, 3" tele halfshafts, modded dragvette loops, 16 gallon fuel cell, basset wheels 15x10x4 with nitto 555r 275/50VR15, 15x12x4.5 with nitto 555r 325/50VR15's, Ultrashield seats, SW Clocks, 16" spal fan, Jones Racing RTP, FIA lights, Mirrors, Action...
  #15
Old 07-21-2015, 03:35 PM
427Swede's Avatar
427Swede 427Swede is offline
Sweden | Addict
My Photos: (116)
Default
I would really change the oil in th tko gearbox after 50 miles. I changed my oil after 2 (!) miles and I was chocked by the amount of particles that came out with the oil... Just not small particles but actually large metal chips from the milling of the aluminum housing !
I then changed oil 2 more times during the first 1000miles and now, after almost 2000 miles the oil is clean.
My tko came from Keisler, hopefully your distributor did a better job of cleaning the casing than the people at Keisler.
I'm super happy with my tko600 now and it has really started to become smoother during shifts.
  #16
Old 07-23-2015, 02:55 AM
MYBAD79's Avatar
My Photos: (882)
Default
Really??? Holy crap now I'm paranoid and will drain the TKO hopefully this weekend .... Mine is from Keisler as well and I expected that thing to be clean and not full if aluminum shavings .... Too bad there's like $50 Synchromesh in this TKO .... I hope it is clean ....
  #17
Old 07-23-2015, 03:26 AM
JPhil's Avatar
My Photos: (140)
Default
Yeah, good thought. From the looks of it all as it arrived from SST, I would be very surprised to find crap in it, but it is a fresh new trans so there's bound to be some stuff. I'm still running the DexMerc ATF as they recommend for break in, but I too will change it out this weekend. I'll have about 200 miles on it and I will replace it with more of the same for the rest of the 1000 mile break in period before I put in the GM Synchro fluid.
And for a progress report: I can feel it loosening up, becoming easier to shift. I've only stalled it twice, starting in 3rd instead of 1st. OK, and once in reverse. Hey, gimme a break! For almost 15 years it was an automatic! I'm getting used to the ratios & matching the shifts, and trying real hard to resist hotrodding it. It just cruises so nice and easy though, that's not a big problem. It's fun watching my new A/F mixture & vacuum gauges too.
  #18
Old 07-25-2015, 11:22 PM
JPhil's Avatar
My Photos: (140)
Default
Flushed mine out today--With 400 miles on it, it was as pure and clean as I've ever seen a fluid come out of a gearbox of any kind. Nary a speck nor sparkle in it. Made me feel good to see.
  #19
Old 07-29-2015, 02:10 AM
JPhil's Avatar
My Photos: (140)
Default
Here is my chassis dyno readout for the TKO600. It uses one half the power of the TH400. The auto sucked 25% of engine power, the manual only 12%. I gained 60 lb/ft of torque and almost 50 horsepower to the wheels.
Why didn't I do this years ago? The car now performs like it was meant to.
Edit: Woops, I meant to put this in my dyno comparison thread. Oh well, it's in both places now!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
