Go Back   VetteMOD.com > VetteMOD Technical Discussion > Drive Train
Reply
Thread Tools
  #1
Old 06-11-2015, 07:41 PM
69427's Avatar
69427 69427 is offline
United States | The Artist formerly known as Turbo84
My Photos: (2)
Default Late C3 and C4 differential fill plug size/threads
I'm adapting a C4 D36 batwing to my C3 differential to pull a few more pounds off the car. C3s have the fill port in the cover, while C4s have the fill plug in the differential housing, hence there's no built in way to fill the differential once these parts are bolted together. I need to drill and tap the C4 cover (somewhere), and if I have room I'd like to use the factory plug (otherwise I'll just use a smaller pipe plug in there somewhere). Anybody know what the thread size is for the fill plug in the C3 batwing and the C4 diff housing?
Thanks for any help!
  #2
Old 06-14-2015, 01:51 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
If you go custom drill 2 holes. One for a level plug and another for a fitting and remote filler line. Much easier that way. As for the thread...no idea. Maybe metric but thought it was an npt size
__________________
  #3
Old 06-14-2015, 06:36 PM
69427's Avatar
My Photos: (2)
Default
Quote:
Yeah, that's not a bad idea. Thanks.
  #4
Old 06-15-2015, 06:09 PM
84rzv500r's Avatar
84rzv500r 84rzv500r is offline
United States | Knows just enough to be dangerous!
My Photos: (105)
Default
ok not to hijack but WTH... where do I put the holes in the C3 Iron diff for my rear diff cooler set up... I cant find the specs and I know Ive seen them somewhere... oh never mind i found them in my 2nd edition Power manual 1/2in NPT sucks to get old and CRS Syndrome
Be sure radius the edges of the holes nicely
I found some nice used NASCAR set ups and I will just run an 12V motor instead of the pinion shaft pulley,,,
__________________
1971 Can-Am, 502 Ramjet, CC Rollers, hookers, 14 pt cage, Lakewood, McLeod RST DD, ROD 6 trans, 3.08 rear, Wilwood brakes, Hydraboost, Steeroids, Tubular A-arms, QA1 DA and Viking DA shocks, VanSteel HD offset TA's w/Johnny Joints, 6 link, 3" tele halfshafts, modded dragvette loops, 16 gallon fuel cell, basset wheels 15x10x4 with nitto 555r 275/50VR15, 15x12x4.5 with nitto 555r 325/50VR15's, Ultrashield seats, SW Clocks, 16" spal fan, Jones Racing RTP, FIA lights, Mirrors, Action...
  #5
Old 06-15-2015, 07:47 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
United States | Addict
My Photos: (0)
Default
I was thinking 1/2 NPT was the right size, thanks for the confirmation. NPT is tapered, make sure you don't cut too deep with the tap.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
