Go Back   VetteMOD.com > VetteMOD Workshop > Fabrication Section
  #1
Old 04-12-2015, 11:29 PM
JPhil's Avatar
JPhil JPhil is offline
United States | Huh?
My Photos: (140)
Default Johnny-bilt hand crank "starter" motor
I need to index my bellhousing for my new TKO600 with the engine in the car. Yeah it would have easier to do when the engine was out but oh well. My SFI rated bellhousing does not have an inspection cover to put a flywheel wrench on. Turning the engine over by the front pulley nut with a socket and big ass breaker bar is a real drag and always makes me nervous.
Gotta be a better way to turn the engine over by hand.
So I went to a starter & alternator rebuilder and got a junk starter motor for free to see if I could make one I can put a wrench on to turn over the engine by hand from below. Here's what I came up with:
Started by stripping the guts out. I replaced the solenoid throwout & spring with a piece of 5/8" heater hose to keep the gear out permanently.
I cut off the commutator & armature by sawing opposite sides to the shaft & splitting it off with hammer & chisel.
Fabbed up a planetary gear retainer & and a shaft end support bushing from some polyisocyanurate (?) plastic I had left over from the pressure brake bleeder I made a couple months ago (another fun project that came out well!).
Cut a snap ring groove to locate the shaft in place.
Filled the shaft splines with JB Weld (it's very low RPM and very limited use so I figured that will be OK) and filed it down to just under 9/16" diameter, the OD of the splines.
Ground down an old 1" milling machine cutter to fit in my drill press and milled down the motor end cap bushing so the plastic piece would seat against the end of the cap but still have some metal bushing for the shaft. Then I drilled out the plastic support & end cap to 9/16", assembled together for alignment
Cut off the last 5/8" of the shaft which originally was in the end cap bushing. The diameter of the next step of the shaft was perfect to file a square 3/8" socket drive end on it. Cut off the solenoid "tower" and made a little tin cover for the hole. Cut a couple 3" long pieces of 10-32 all thread to make shorter through bolts.
Here's a couple pre-assembly views as it all went together:
And voila! It's even already painted "Special Tool Red."
I haven't tried it on the car yet of course, but it spins and with the gear reductions of the planetaries & flywheel, I expect it will hold up & work to slowly turn the engine over.
It took me about 10 hours or so to make-- lots of pondering involved. The only thing I had to buy was a 9/16" drill bit. I'da sworn I had one, but I didn't. Now I do.
Fun project!
Kill the Buddha
  #2
Old 04-13-2015, 12:29 AM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Most all engine blocks I have seen have two studs to center up the bell housing, and some 6 bolts to hold it on to the block.....automatic trans has the bellhousing cut back at an angle toward the oil pan....
just why do stick shifts have a totally round housing on the bottom, seems it would be good to ensure more clutch air circulation and do them the way auto trans are....for what it worth, for decades now, I leave the lower sheetmetal trans 'cover' off for better cooling, looking at the engine oil pans or any other item in the way, the last thing to get hit would be the TQ or flex plate, for that matter the fly/flex on a stick.....
be ME, just cut the damn housing. and do what I do....stick a pair of vice grips on the flex....and move the damn thing around, obviously easier if you at least loosen the plugs.....
  #3
Old 04-13-2015, 12:48 AM
JPhil's Avatar
My Photos: (140)
It's a brand new $600 explosion proof SFI 6.1 competition rated bellhousing, Gene. I got it for a reason. I ain't taking a sawzall to it. And new trannys such as the Tremecs are precision machined with a flange that fits into the precision machined opening in the bellhousing and thus need to be precision aligned to the centerline of the crankshaft of the engine. This ain't junkyard parts swapping.
  #4
Old 04-13-2015, 03:24 PM
SuperBuickGuy's Avatar
SuperBuickGuy SuperBuickGuy is online now
My Photos: (0)
that should work slick, nice work
  #5
Old 04-15-2015, 10:46 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (358)
Maybe you have a new business idea?
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. Buckminster Fuller
  #6
Old 04-16-2015, 01:20 AM
JPhil's Avatar
My Photos: (140)
Ya know, the thought crossed my mind, briefly. But then I figured anybody with mechanical knowledge, desire & wherewithall to need something like this could make his own just as well.
It could have been done much quicker and cruder by using a hose clamp & split heater hose for the throwout, a hose clamp & big washer for the planetary retainer, another hose clamp & washer and/or even a little scrap of wood for the rear support, if any. Heck, a scrap of 1/2" heater hose clamped to a socket extension and the shaft would probably turn it.
Or even cruder yet, my very first idea, was to cut off only the commutator, cut down and drill out the end cap, pack the armature housing full of grease and make a tin sleeve hose clamped to the shaft & a socket extension. Use baling wire to hold the throwout fork.
That ain't my style though, when I get to having fun fabricatin'!
  #7
Old 05-11-2015, 05:30 PM
JPhil's Avatar
My Photos: (140)
Works like a champ! Turns the engine over (plugs out) at about one half RPM using my air ratchet.
  #8
Old 05-12-2015, 01:41 PM
My Photos: (0)
Quote:
it depends on the cost, but, while I certainly have the time and space to build that - I wouldn't if I could buy it and save myself 8 hours of labor... plus, that 9/16 bit isn't cheap
  #9
Old 05-13-2015, 02:17 AM
JPhil's Avatar
My Photos: (140)
Geez, SBG, I have to laugh out loud at that, seeing the things you do! Probably 6 hours of it was settin' and thinkin' and revising and drinking coffee and smoking cigarettes and pondering and revising some more.....One of those projects that started out to just be a quickie cobble job and ended up a deluxe 'work of art'.
And I'm sure I'm the only one here who has ever suffered from 'mission creep'!
  #10
Old 05-13-2015, 01:19 PM
My Photos: (0)
mission creep? wouldn't know of it
I do know, however, the if it were to happen to me that it would come from overpondering
  #11
Old 05-13-2015, 07:01 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
My Photos: (0)
Is there some reason to not just turn it over the traditional way, with a breaker bar on the harmonic balancer?
Just curious, this seems like an elegant solution.
  #12
Old 05-14-2015, 02:23 AM
JPhil's Avatar
My Photos: (140)
I don't have to remove the fan & shroud & loosen the alternator to take the tension off the belt & pulley and then dick with trying to get & keep the socket on the bolt head, I don't have to heave on it and worry about busted knuckles or an over-torqued or busted bolt or busted something else in the engine bay, I can spin it in reverse, I don't have to keep crawling under and back out, I get to use power tools and leverage and finesse instead of brute force, I can be precise in how far I turn the engine, and maybe most importantly I got to make a really cool little tool I'll probably only use once or twice, but I had fun making it and it's really cool!
  #13
Old 05-17-2015, 03:14 PM
GTR1999's Avatar
GTR1999 GTR1999 is offline
United States | Gearhead
My Photos: (4)
That, is pretty cool. I like it. Something to build when I get some time! There is a local starter rebuilder here who is going out of business because the chain stores with Chinese rebuilt starters and alternators are killing him.
I'll have to see if he has any old chevy starters around.
Nice idea!
69 SB 4 Spd Vert- under resto(sitting in my garage)
72 SB Auto Coupe- 355,TH400 336's (drive 1k miles yr)
75 L82 4spd Coupe- Gave to my son, the gearhead.(going to 12-bolt,3.5 shafts,& 31 spl axles)
67 coupe- gone but not forgotten.( like to get another one some day)
  #14
Old 05-17-2015, 05:46 PM
mrvette's Avatar
My Photos: (3)
Nice idea!
Just a few short months ago, we lost an olde tyme starter/alternator place here in Orange Park, but the guy was like my age....71+.....he was a good source for parts....
  #15
Old 05-17-2015, 07:58 PM
JPhil's Avatar
My Photos: (140)
Nice idea!
Coming from you, Gary, that is a compliment I can be proud of. Thank you!
  #16
Old 06-04-2015, 02:10 AM
JPhil's Avatar
My Photos: (140)
Default Part Two: Indicator base
OK so the engine spinner works fine but when I went to put my dial indicator on the crankshaft end I found there was no way the mount I had would work. Hmmm...looks like I get to make another tool! Oh boy, this project is turning into loads of fun!
This one was quick: A trip to Ace Hardware for some metric bits to screw into the magnetic base. A 3" M8 bolt and a bunch of nuts. Of course I bought a bunch of other hardware too, just in case this didn't pan out.
Cut off the head of the bolt. Fold, drill & grind a tang on a piece of flat stock for the gauge holder, double nuts for it all. A hose clamp to hold the indicator works fine.Then I decided it needed a handle to work inside the bellhousing. Drill, cut, bend--voila.
This one only took a couple hours including the trip to the store. Worked fine.
The bellhousing dialed in at .0025", well within the max .005" allowed, so no need for offset dowel pins.
The whole dialing in thing only took maybe 45 minutes at the most. Once I had the indicator in place (& the handle made that so easy), I just sat under the car and squeezed the trigger of the air ratchet, took a reading, repeat as needed. I spun it 360* six times, with a reading at every 90*. Then I decided to double check, so I did it again, another six turns, at 90* but 45* from the first set of readings. All measured out equivalent, .005" total runout equaling .0025" misalignment.
  #17
Old 07-20-2015, 05:54 PM
84rzv500r's Avatar
84rzv500r 84rzv500r is offline
United States | Knows just enough to be dangerous!
My Photos: (105)
hello my names is mark and im a/an???
I love it..
guess im not the only one around there are so many custom built tools lying around like a yolk puller for spicer 1350 yokes and a spring compressor Ohlins Monoshocks... oh and a CNC Plasmacutter out of and old computer tape drive robot... and a R8 CNC mill... and we built the DC power supplies for the stepper motors too out of old computer parts...
1971 Can-Am, 502 Ramjet, CC Rollers, hookers, 14 pt cage, Lakewood, McLeod RST DD, ROD 6 trans, 3.08 rear, Wilwood brakes, Hydraboost, Steeroids, Tubular A-arms, QA1 DA and Viking DA shocks, VanSteel HD offset TA's w/Johnny Joints, 6 link, 3" tele halfshafts, modded dragvette loops, 16 gallon fuel cell, basset wheels 15x10x4 with nitto 555r 275/50VR15, 15x12x4.5 with nitto 555r 325/50VR15's, Ultrashield seats, SW Clocks, 16" spal fan, Jones Racing RTP, FIA lights, Mirrors, Action...
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
