Go Back   VetteMOD.com > VetteMOD Technical Discussion > EFI
  #1
Old 09-23-2014, 09:02 AM
Belgian1979vette's Avatar
Belgium | Addict
My Photos: (104)
Default Aeromotive fuel pump speed regulator
Did anyone ever use one of these ? Did it silence the pump and keep fuel cooler than without it ?
Opinions are like assholes, everyone has got one, but everyone thinks everyone else's stinks.
  #2
Old 09-29-2014, 06:35 AM
Stroker-427 Stroker-427 is offline
Italy | Addict
My Photos: (39)
I use one of that.
I have a big Aeromotive A1000 pump under the tank which was pumping a lot to much gasoline under light driving, so I istalled the speed regulator.
The one I have is only reducing the pump speed when the engine is under 3500 RPM.
The main purpose is to avoid to much bypass flow at cruise..... and longer pump life.
  #3
Old 10-01-2014, 02:39 PM
Belgium | Addict
My Photos: (104)
Quote:
Originally Posted by Stroker-427 View Post
I use one of that.
And how did the sound evolve ? I think the pump is rather noisy especially on low rpms.
So you run high pressure lines all the way from the rear to the front ? I assume you put the pump and everything where the spare tire is ?
  #4
Old 10-09-2014, 11:05 PM
Italy | Addict
My Photos: (39)
The noise is basically the same.... only with a bit lower pitch.
Yes, I have the pump and both filters (one before and one after the pump) in the spare tire area (no more spare tire).
Both high pressure and bypass lines are braided hoses, the pressure regulator is near to the front right wheel..... in order not to have fuel pressure drop under hard acceleration.
