Go Back   VetteMOD.com > VetteMOD Technical Discussion > EFI
Reply
Thread Tools
  #11
Old 05-22-2014, 03:53 AM
camden camden is offline
United States | n00b
My Photos: (0)
Default
Quote:
Originally Posted by Belgian1979vette View Post
I'm trying to assemble some smaller diameter Aeroquip hose (-6 and -4). With the bigger sizes I never seemed to have any problems, but with these lines I can't seem to keep the braid on it.
The procedure I use is :
- wraping the hose with tape
- cutting it off with a cutting wheel
- taking the tape off and trying to put the cap on
What's the trick here ?
Same process here except when it comes to sliding on the fitting. I have 2 rubber bushings I put on either side of the fitting and snug it down in vice. Start inserting one side and then take a small flat head screw driver and push the braided pieces in while pushing or turning the hose. So much than tearing you fingers up.
__________________
pictures:[Only registered and activated users can see links. Click Here To Register...]
video:[Only registered and activated users can see links. Click Here To Register...]
  #12
Old 05-22-2014, 04:07 AM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
Damn that chisel cut is the way to go !!! Holy crap I have to try that !!!
Thanks for sharing that video !!!
__________________
Link to my garage:
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
