  #191
Old 01-03-2018, 05:27 AM
SuperBuickGuy's Avatar
My Photos: (0)
the absolute best thing about fiberglass is how easy it is to fill gaps.... matter of fact, perfect fitment is not a goal since you want the glass and resin in the between the parts.... this is the easy part, making them smooth - especially since I was the 2nd person to get these flares - will be bit of a task
time to get this where it needs to be - first get a bit of aluminum to make a ledge
these blades work awesome at cutting fiberglass
nice, straight cut
back to the ledges
cut 1" (and the lip) off the rear panel so they butt together
and time to take it off its suspension so that I can verify dimensions
tomorrow, the front panel comes off and I start making those fit.
  #192
Old 01-05-2018, 05:30 AM
My Photos: (0)
It's getting there
much better alignment
oops, the plastic is just falling off now
I think I'm getting the hang of this - this fender took 1 hour to remove, then get back to this point
Of course, I'm now down with this part....edited
this is the right way to save that vent
and a back shot
oh look, I even saved the build sheet
  #193
Old 01-08-2018, 05:13 AM
My Photos: (0)
time to start coloring inbetween the lines... you know, all the boring stuff that must be done that didn't get covered on first swipe
like bolting the fuel pump in and finishing the lines
a couple zerts
and it's in place
then this, and I don't know what the solution is going to be... the fuel lines and the bracket occupy the same space
tried another fuel line, no joy
stopped with that annoyance and did a bit of rewiring
which lead into a lot of wiring
long ago, I learned the lesson about having operating gauges for first fire
and now to decide if I just finish with all similar gauges or save a couple bucks and put the fuel gauge and the clock back
lots of other stuff got done - mostly my wife's Jeep - but that one is going to wait until completion to be blogged....edited
  #194
Old 01-10-2018, 04:51 AM
My Photos: (0)
so swapping bowls and accelerator pumps
and removal of a vacuum port
and figuring out how to get the line bent with no kinks
like this
then throttle cable
and repurpose the old air cleaner I made for P1 ... not final product, but good enough to keep the dust out
then do a vacuum test on the cooling system
no, it didn't hold pressure long, however, it did well enough that I'll fill the system just before I start it with far less fear that there are any major leaks
  #195
Old 01-10-2018, 05:43 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
I donít know about road race, but a regulator on the fire wall is a no go for nhra.
  #196
Old 01-11-2018, 04:47 AM
My Photos: (0)
I dunno, I've never run a sanctioned NHRA race in my life.... I do open track days and autocross (and would never dream of racing on the street... never )
yipee.... electrical
looks like it had a jacobs ignition box....edited
I just needed to remove the speedo cable
and then I found these Bubba devices
you will be glad to hear that the speakers have been removed.... now to reassemble with better wiring
for those curious, I'm tackling the wiring because I need gauges to work when I fire the motor.edited Not just that but I also need to wire the fuel pump, electric fans, and master switch.editededited
  #197
Old 01-12-2018, 05:39 AM
My Photos: (0)
this is going to happen soon
anyway, break is over... much little work done
gauges
and determining air filter height
3" filter, check
vB code is On
Powered by vBulletin® Version 3.6.8
