  #411
Old 10-03-2018, 11:57 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (166)
Nice hood !
If I have to lift the body off the frame again, I would remove the behind the seats boxes, make an alloy cradle for the batt and have plenty of space/cooling around the diff.
About the doors, I thought about "holing" the steel bottom of them, hard to see if you don't know
  #412
Old 10-03-2018, 01:24 PM
vette427sbc's Avatar
My Photos: (47)
Quote:
Originally Posted by stingray composites View Post
what about a 8lb hood?
Love the figures on the hood but I want to see a 1 piece carbon targa!!
Quote:
I like that idea! Dont think Ive seen it done before
Chris
AutoWorks Middletown NJ
@autoworksnj
  #413
Old 10-04-2018, 11:51 PM
stingray composites's Avatar
stingray composites stingray composites is offline
United States | n00b
My Photos: (3)
dynamic vettes has a one piece targa top right now. Their "carbon version" weighs 17.7lbs for $2,100 per their facebook post.
once Im done with these hoods doors and t tops are the next big projects, then a solid top
dedicated to carbon fiber for c3s! [Only registered and activated users can see links. Click Here To Register...]
  #414
Old 10-07-2018, 03:03 AM
69427's Avatar
69427 69427 is offline
My Photos: (2)
Made up the battery (-) ground wire using the stranded aluminum wire I got at the scrapyard the other week. The piece ended up 40% lighter than the copper wire. Not much actual weight removed though, as the original ground wire wasn't that heavy to begin with, but I needed a practice wire to work on before I tackle the main + line from the battery. I made my own terminals from aluminum tubing, as I couldn't find any aluminum terminals at a local electrical warehouse. I sanded and brushed all the electrical surfaces to remove any oxidation, and then crimped and welded (via a couple drilled holes in the terminals) the assembly to hopefully get a decent electrical connection. I then just taped over most of the interface area to slow down future air leakage and oxidation.
I have one end of the larger diameter positive battery-to-starter wire finished, but it looks like it will take some time to extract the original cable out of the tunnel area, so this portion is on hold until I finish a couple track days I'm trying to squeeze in this month.
In the mean time, I'll make another short aluminum replacement ground wire between the starter housing and the frame. This will only be another few ounces off the front of the car, but it will at least remove the annoyance/distraction factor that hits me occasionally when I'm on the track and I keep thinking about unnecessarily heavy items on the car. Last week I did take a few pounds off the front of the car with modifications to the steering rack mount, the alternator bracket, the water pump cover, and a frame crossmember.
I did take an additional 12 temporary pounds off the car a couple weeks ago when I pulled the passenger seat off, and bolted on an additional fire extinguisher bottle/bracket for this month's track days.
  #415
Old 10-07-2018, 03:54 PM
My Photos: (47)
for sealing the ends of your battery cable... there is heat shrink that has adhesive on the inside. It melts and seals the connection very well. Sometimes called marine heatshrink.
"NTE 3/4" Dual wall polyprolefin adhesive heat shrink tubing" is what I use when making battery cables
  #416
Old 10-09-2018, 12:44 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (166)
Did you checked the corner weight of your car? Just for me to have an idea of comparison with mine. I did find that the balance front to rear is not that bad, with a small block.
  #417
Old 10-09-2018, 02:43 PM
69427's Avatar
My Photos: (2)
I don't have access to any wheel scales (or the available funds to buy a set), so I have no accurate idea of what the numbers are. My brute force plans presently are to make another trip to a nearby truck stop to get the car weighed on their scales. I've previously gotten the F/R weights of the car by parking the car with the axles on two different segments of the scale. A while back I thought about also parking the car sideways on the scale segments, to get the L/R weights. Then, I (hopefully) could do some math to derive the four corner weights from the two weight printouts.
In the mean time, I'm just pulling off excess weight wherever I can find it.
  #418
Old 10-10-2018, 10:02 AM
phantomjock's Avatar
My Photos: (698)
I bet Heartland has a set of scales in impound. Might be worth the trip one weekend for a track day. Or at least a phone call. Probably more accurate.
Rebuilder's Zen Saying:
  #419
Old 10-31-2018, 11:19 PM
69427's Avatar
My Photos: (2)
Quote:
I couldn't get my schedule open to match the infrequent scheduled track days at Topeka this year (But thankfully Raceway Park of the Midlands in southwest Iowa has open track days every Friday), but it might be worth asking at Topeka next year. The worst they can do is say NO.
  #420
Old 10-31-2018, 11:34 PM
69427's Avatar
My Photos: (2)
Found myself with a couple hours of free time on a pleasant fall day today, so I hit up one of the local junkyards. I wandered off the usual section of GM cars and looked at a few other domestic and imported brands. I saw a wide variety of aluminum radiator sizes (I'd like to pull a couple more pounds off the front of the car with a lighter radiator that holds less water), and a few models that are equipped with aluminum housing p/s pumps. One complicating issue with these later pumps is that they all have serpentine belt type pulleys. I need to do some work to see if I can modify a v-belt pulley to fit a newer pump.
If the prices aren't too outrageous it might be worth the effort to try installing these items for a little more weight off the front end.
