#32
![]() A company spends all that money, in marketing, research, product support ... and throws it all away with poor quality products
I wasn't going to call out Howell EFI, but this is ridiculous. To remind. The '40 died at a stop light and wouldn't restart. It was blowing the main fuse for the computer. After 4 hours of diagnosis, I thought I found the issue and fixed it - no, I just spent needless money. I presumed that Howell had done a good job - that was a mistake on my part. Electrical tape is a wonderful, TEMPORARY wire cover. While it was covered by the loom, the problem was when they soldered the joints, they didn't trim the flash (the pointy ends of the wires) nor did they crimp them flat.... best practice is heat-shrink tubing... which it has now. [Only registered and activated users can see links. Click Here To Register...] Mind you, I wouldn't be so irritated if I'd not already bought a harness at UPullIt that I simply needed to do what I did today to the Howell harness - that is, trim, solder and cover with heat shrink. Secondary to the above issues is they didn't trim the ends of the plastic so it could rub its way through the wire.... oh yeah, the irritation... $400 I spent on their crappy work. notice the nice, sharp edges and the forced 90 degree bends that bent against the loom cover? [Only registered and activated users can see links. Click Here To Register...] that ball in the middle, had nice ends sticking out - that's what shorted and why when I originally loosened the harness, everything worked again [Only registered and activated users can see links. Click Here To Register...] why not heat shrink? because everyone loves to look at electrical tape falling off? [Only registered and activated users can see links. Click Here To Register...] I feel better about my soldering too [Only registered and activated users can see links. Click Here To Register...] What's really special is the short wires that are soldered on both ends.... black wire must be hard to come by? [Only registered and activated users can see links. Click Here To Register...] 5 solder joints, one wire.... no heat shrink.... [Only registered and activated users can see links. Click Here To Register...] note the electrical tape coming off a main power wire? this was the short [Only registered and activated users can see links. Click Here To Register...] if only it had looked this good before I re-did it [Only registered and activated users can see links. Click Here To Register...] I re-ran the wires a bit [Only registered and activated users can see links. Click Here To Register...] and finally got around to the 2nd defrost hose [Only registered and activated users can see links. Click Here To Register...] drilling hole [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] believe it or not, I think I'm going to leave it like this.... no pinch or rub possible [Only registered and activated users can see links. Click Here To Register...] I still need to loom the rest of the wires and find out why the gauge isn't working (again) my table will get cleaner this week... [Only registered and activated users can see links. Click Here To Register...] |
#33
![]() I haven't updated in awhile.
The radio/dash install went great [Only registered and activated users can see links. Click Here To Register...] basically this is an example of the stupid little nut and bolt stuff that takes forever but needs to be done - in this case, I'm still not convinced I need a snorkel. I live in Washington and I'm not sure there is any place in the state where there is a legal water crossing that is higher then this.... so why have a snorkel? I may change my mind, but that would be after I blow up a motor... [Only registered and activated users can see links. Click Here To Register...] I made an executive decision and decided on a top-end custom top... which starts with a stock soft-top frame work [Only registered and activated users can see links. Click Here To Register...] not done yet, but I'll post pics when its done and then I spent a lot of time fixing Howell EFI wiring problems.... $400 for a harness that I had to take apart and fix. Howell, when I asked for help, ignored me.... so I advertise for them... [Only registered and activated users can see links. Click Here To Register...] So this is stupid.... this tells you little about how a vehicle will perform off-road, but it's like a dyno number - it gives you an idea of what the performance will be [Only registered and activated users can see links. Click Here To Register...] it also shuts down the trolls. The score was 1008. My H3, which is pretty capable off-road, would probably score in the 600-700 range (by way of comparison to a stock, offroad vehicle) |
#34
![]() I laughingly call this my "no toyota to be seen" picture. If you add up the sum total of the three rigs in the forefront, you wouldn't have enough parts between all of them to make one, all-Toyota vehicle
[Only registered and activated users can see links. Click Here To Register...] but this is the natural habitat of what I built it for. I think it turned out okay [Only registered and activated users can see links. Click Here To Register...] my dog in his natural habitat.... when it snows, you can't drag him inside [Only registered and activated users can see links. Click Here To Register...] off to our left is a dog [Only registered and activated users can see links. Click Here To Register...] a dog with jowls a flyin' [Only registered and activated users can see links. Click Here To Register...] who woofed at me because I'm laughing to tears [Only registered and activated users can see links. Click Here To Register...] because he's stuck [Only registered and activated users can see links. Click Here To Register...] time for 4 paw drive [Only registered and activated users can see links. Click Here To Register...] success! [Only registered and activated users can see links. Click Here To Register...] time to head back to the rig to fall asleep [Only registered and activated users can see links. Click Here To Register...] that, my friends, is a typical day of 4wheeling, SBG style. ![]() |
Thread Tools | |
